'94 22RE downpipe replacement.
Old Mar 15, 2008 | 09:56 PM
kmat123's Avatar
I have a pretty bad exhaust leak in the downpipe on my '94 pickup. I would ideally like to replace my manifold and downpipe/front pipe, etc with an LCE header, but that is unfortunately not in my budget right now. I was wondering if anyone knew a good source for new or refurbished downpipes? Also, how involved of a job is this? I'm sure it won't be anything compared to replacing my clutch today. Thanks!
Old Mar 15, 2008 | 10:35 PM
94toy4x4fever's Avatar
go to just about any muffler shop they should have some down pipes laying around! I had the same problem with mine. It was cracked between the two pipes. So I just got a header off of ebay and got rid of all that crap! Changing that down pipe wont be that hard. You will have to pull the manifold off and cut the bad pice out. Or you could try to get in there and re weld it but it might now work. Good luck to you! Later
accuracy
Aug 6, 2015 12:32 PM
accuracy
Aug 4, 2015 08:05 PM
skoti89
Jul 8, 2015 12:05 AM
cyclist231
Jul 7, 2015 12:56 PM
