- Exhaust collector nuts
- Temp and fuel sender help!
- Anyone bought from JISENGINE.COM??
- 93 4runner, alternator problem?
- Hesitation when starting
- Won't keep running
- Charging and cooling issues
- 1990 2wd 3VZE auto starter removal help needed
- Do you rinse the salt off?
- PLEASE HELP 91 3vze 4runner
- 1 more auto trans question
- Overdrive light question
- 91 SR5 4runner
- RTH driveline vibration
- Spare tire rack
- My Son`s 94 4x4 v6 % Sp. With Clutch Problems
- exhaust pipe broke before the cat :(
- okay, do yota engines need this?
- Whats an 88 4runner worth???
- Parking Lot Poser Shots
- 1991 Rear Window does not roll down but will roll up?
- 89-95 4Runner Trim Removal
- Rear Spring Leaf Hanger Bolt Kicked my Arse
- Code 24
- 92 22re gauge swap
- Code 51
- 1stgen's new trucks!!!!
- failed emissions
- Exhaust gaskets R&R, '95 4Runner 3VZE
- Diagnostic mode - idle does not drop
- grease or replace bearings
- 4runner Softtop/Canback Question
- universal stock brush guard?
- Neading some upgrades for 95 4runner 3vze
- 4 wheel disc break pickup help
- new to me 1986 4runner
- adjusting the tps
- High idle, now low idle and stalling with check engine on
- 3vze winter starting problem.
- Exhaust upgrades on 22re
- new 22re surging
- my 1987 ex cab pickup wont stay timed!!!
- How long should spark plugs last?
- 22re idle adjustment screw factory setting
- turn signal issues...
- V6 Diff Swap - What do I do with this?
- 3vze airbox on 22re
- motor is toast. happy new year!
- sub oxygen sensor
- 2nd Gen Wiring Led's
- engine bog when temp rises
- out of the blue; won't start.
- New 22Re dragging
- odd ticking sound
- Rear wiper problem
- A/T overdive kick in and out
- Did I blow a cv axle?
- When's the best time to rebuild?
- 1st gen 4rnr plater bumper + stinger
- E-Brake Mystery
- Lucked out on heater
- WTB TVV for a 95 pickup
- WTB tvv part number 90925-05047
- Cylinder Honing
- Ain't whistling Dixie (Toyota 3L V6 whistle)
- OIL spitting everywhere? Any ideas???
- Nitrous Oxide Systems V6 EFI Sniper Kit
- 22re TPS replacement - now motor surges repeatedly
- 1986 4runner running to cold?
- Mystery Miss!!
- Front IFS Diff support BUSHINGS
- Weber 32/36 DGEV 22R conversion questions
- Help with 4 runner please/power steering
- PS pump is making some noise
- 2nd/3rd gen tail light differences
- Hard to turn engine over
- Duel Transfercase crossmember
- are 86-95 ifs all the same and compatible other than ADD?
- 87 4Runner CEL
- a 22re, and the disappearing oil mystery...
- Roof Rack Leak?
- Ah Yes; 4Runner Rear Window
- Couple of strange issues
- 89-94's, rattling sounds, leaf springs and dash lights
- another rear window help topic
- Truck cab smells like fuel
- RedRunnerTC's rear axle swap after accident (with his 93 4Runner Ron)
- Camshaft bearing help? Please?>
- Crankshaft bearings shot! A litte help plz?|
- Post Water pump replacement / AC Removal?+
- front eat works intermittently while rear is ok
- Rancho rs9000xl shocks
- Forever warming up...
- 90 4runner rubbing noise?
- Torsion bars
- '98 4runnerr rims on '86 P/U???
- Clunk in rear
- Warn Hub question
- A few new problems. Tranny, Exhaust indications?
- almost killed in snow (driving tips needed)
- 90' 4Runner chop
- Load Tie-down Hooks / Saddles for Pickup Tub
- TPS Measurment Help
- new windshield trim
- 22RE rebuild help
- Intermittent Front Left Hub Vibration
- Bent Valve/timing chain Questions
- Front end shake from 60- 65
- 1992 Truck Won't Start
- Failed emissions but have brand new catalytic converter?
- Gauge Pod for pillar
- Heater core change-out on a 91 PU!
- engine lopes when brakes appled
- K&W Block Seal Head Gasket Repair
- Testing MAF
- clacking noise when engine is cold
- How to fix horn - 88 runner
- Bucking 22R engine
- Water Pump
- door question
- Ifs
- Is my transmission mount supposed to look like this?
- 94Toy 4 coolant leak
- O2 Sensor
- Myth Busters ** e-locker conversion axle length **
- 22re HG dilemma
- 95 SR5 Dash Light Help
- Roll Bar, Shell Combo?
- Hella 500FF going on new AOR bumper on 3rd gen PU
- 22re heater valve/hose
- 1988 4x4 Exhaust Replacement
- *Quiet* performance muffler?
- throwout bearing spring clip orientation (need pics) help please
- a change of hubs
- frame cab mount question
- Added some front tow hooks
- Truck dies when accelerate
- Fuel not making it the whole way.
- Headlight problem
- really bad mileage
- High Cold Idle
- 94 Truck E-locker install in progress
- 4 questions, transfer case, wheel bearing, 3rd member....
- Several problems: Transmission, O/D light, Power questions
- Back-up light problem and solution
- 4Runner Rear Heater ?.
- throttle body spacer
- Engine noise in 93 22-re
- Used MAF? Yay or nay?
- diesel yota oil seal
- 3.0 Bad Rod knocking. (Video)
- 94 4runner 4x4 shifting problem
- 95 4runner radio swap
- Tie rod replacement
- 88-22re - wont start!!!
- My motor died
- 1987 extra-cab 4x4 motor knocking...
- Strykersd's first gen 4runner build
- Reverse lights stopped working
- Left the emergency brake on while driving, what did we break?
- 86 4runner shifting problems.
- 93 4runner cv joint shot!!
- My 90' 4Runner
- Truck sluggish when going uphill
- My cure for cancer, what do you think?
- Decided to do the head gaskets
- Approach to fuel sending unit in '88 4Runner
- Code 43 (22re) question
- toyota doors
- horn question;
- 2000 civic buckets in place of 40/60 bench
- Crank Bolt won't budge
- Hubs?? CV's?? something else??
- I'm stumped. Wont start unless I move VAF lever
- 22RE Idle
- 1st gen runner
- 300 000 km yesterday
- Upgrading Headlight Wiring Harness
- Gas Mileage Improvement Testing
- Spare tire on top of a 4runner?
- Oil pressure gauge fluctuation
- Broke Bolt in Spring Seat When Changing Shocks
- My power outlet plug in
- Question on ADD 4X4
- rear heater hoses (which is in and out?)
- Custom ARB bumper install
- HELP ME! Crack head? Tons of Coolant Pressure
- Not warming up mystery
- JT Outfitter Headers for a 93 22RE
- What is this bushing called?
- TPS question
- fuel issue on 86 toyota pickup help plzz????
- Failed low speed emission but passed last year!
- TB/IAC coolant bypass
- Question about 2nd gen 4runner
- My dipstick tube won't stay in the block
- alt. bracket bolts
- Strange Intake Sound ***VIDEO***
- Electronic rust prevention?
- Upgrade Ignition??
- Please help, having trouble pulling E-locker 3rd
- wont start error codes 22, 24, 31 , 41
- Just scored an E-locker / have questions.
- no pwer at all...fuel problem?
- shackles / bushings that will work with my Downey springs now that they are closed???
- Oil Cooler)
- tailgate handle help
- cracked dash repair. what to use
- Snow and ice.... bad brakes.... Guess I'm going to the shop.
- Cold weather causing leak?
- Head Gaskets are pretty much gone!:(
- Leaf spring keeps kreeping over
- almost stalling
- Sluggish motor
- Dead 3vze
- 92 Runner needs new exhaust
- arb bumper
- FINALLY! 88 tailgate. (pic)
- 1986 4runner shifting problem?
- Vent under the driver's side dash?
- 92 22re no high idle on cold morning and hesistates when accelerating
- 94 pickup snow pictures
- 86 22r tranny 5sp.
- Exhaust Nut
- "Zuk" Spring Mod With No Welding or Bolting
- Anybody else's calipers do this???
- Squeaky noise and Wobbly PS Pump Pulley (3.slow)
- OME 900 coils
- New 15 10 rock crawlers on my runner
- rering or rebuild
- Where do these brackets go?
- door panel pins
- Need Help. Only starts when I move VAF
- Charging issues
- '91 4runner 22r to 22re swap engine running problems
- body lift with auto tranny
- Parts compatibility between year models
- 89 1st gen 4runner glove box light and switch
- Radiator replacement
- Rn61-64-66 ????
- Copper Exhaust Mani Gasket?
- 1994 3.0 vacuum hose diagram
- another dumb question on diff's.
- 87 4Runner Rear Window
- TPS necessary?
- dual case adapter?
- Best Truck (Toyota) Magazines
- Friends 1988 runner
- My timing does not advance!
- towing 4k lbs with a marlin rear bumper?
