Front end shake from 60- 65
Old Dec 28, 2009 | 06:44 PM
jrobertson4runnner's Avatar
Before you guys say anything, I have searched this. I drive a 91 4Runner, 3.0, 5 speed, and of course, 4x4. I have recently noticed that at 60 miles an hour, there is a pretty hefty shake, that continues up to 65. Now, as soon as I reach 65, the shaking stops, and I can control the truck better. I read a thread about doing a mod on the steering rack bushings, but I don't know if I have a rack & pinion steering system or not ( I'm still learning a lot about this stuff). Let me know what you guys think.
Old Dec 28, 2009 | 06:47 PM
93YotaMonster's Avatar
tires out of balance, u joints, wheel bearings, maybe.
Old Dec 28, 2009 | 07:57 PM
94toy22re's Avatar
Mine used to do the same thing, try replacing the idler arm.
Old Dec 28, 2009 | 09:21 PM
abecedarian's Avatar
you do not have rack-and-pinion.
check wheel balance, like mentioned, and maybe the steering dampener (if equipped).
Old Dec 28, 2009 | 09:55 PM
thedanned's Avatar
You may have picked up some mud on the inside of the rim, causing a wheel to go out of balance. A wheel weight may have fallen off too.
Old Dec 28, 2009 | 11:27 PM
gary96360's Avatar
my truck did that when the rim was caked with mud inside the rim and it was pretty bad
Old Dec 29, 2009 | 06:16 AM
94svt50's Avatar
Get the wheels balanced, should take care of the shakes. These older wheels tend to have wheel weights in abundance, no big deal to sling one off.
Old Dec 29, 2009 | 01:11 PM
I recently had the tires mounted on some different wheels( I call them rally wheels, but I don't know if that's correct or not) and they supposedly balanced them then, but you never know I guess. Thanks for the tips guys, its appreciated. Abe, how do I find out if I have a steering dampener? Is that something that came factory, or is it an after-market thing? Thanks again guys, and as before, I am still learning a lot about these trucks.
Old Dec 29, 2009 | 03:34 PM
94svt50's Avatar
The steering dampner is that thing that looks like a shock only its mounted horizontal on the center of the steering components under the truck. Factory item.
Old Dec 29, 2009 | 05:17 PM
Thanks man. Im guessing I should look for general signs of wear and tear? weather here has been crappy all day long, so I may check it out tomorrow. Thanks again.
Old Dec 29, 2009 | 06:00 PM
Mudd Duck 1's Avatar
also someone mention your idler arm you dont have to replace the whole thing toyota sells bushings for it so you can rebuild it i had to when i bought my runner
Old Dec 29, 2009 | 06:13 PM
Thanks Mudd Duck, I'll look into that. seems like most of this stuff is pretty easy to fix, right? or am I totally off-track on some of it?
Old Dec 29, 2009 | 07:20 PM
thedanned's Avatar
These trucks are easy to fix once you understand their idiosyncrasies.
So by your post above, the shake started after you had your tires mounted on those new wheels? Out of balance wheel, bubble in the tire plies (IE time for new tires), or a bent rim would be where I would start. Rotate the tires from front to rear one side at a time and see if the shake changes at all, and you may find your culprit wheel...
Old Dec 30, 2009 | 11:24 AM
i agree with "thedanned" i was just throwin' that out there seems like alot of people buy the whole part when they could rebuild the one they have but your prob is (imo) somethin to do with those wheels or tires or it could be a steering component you can always just climb under there and look it all over good make sure there's no excessive wear
Old Dec 30, 2009 | 01:28 PM
Thanks guys. I will do some checking on it in a few minutes. I will try the tire rotation, and see if that works or not.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
Daneums
Aug 20, 2015 05:36 AM
v_man
Jul 23, 2015 04:01 PM
