door question
Old Dec 27, 2009 | 06:24 PM
90veezee3's Avatar
door question
Its simple. I need to replace the doors on my 90 p/u ext. cab and I found a guy on craigslist parting out a 91 4runner. I searched but couldnt find my answer. I just need to know if the doors are the same size and whatnot and if they will fit. Thank you ahead of time.
Old Dec 27, 2009 | 06:44 PM
milehigheric's Avatar
2 door or 4 door runner? The length changes between single and extra/dualy.
Old Dec 27, 2009 | 07:04 PM
90veezee3's Avatar
its a 4 door. heres a pic of it
Old Dec 27, 2009 | 08:09 PM
85yota4x4's Avatar
i think they are diffrent but could be wrong
Old Dec 27, 2009 | 09:19 PM
Matt90V6SR5's Avatar
I think they not fit,shorter in length.
Old Dec 28, 2009 | 03:01 AM
Yes correct...extra cabs are the same length as single cab pick ups or 2 door runners. Duallys and 4 door runners are interchangeable.
Old Dec 28, 2009 | 03:03 AM
space-junk's Avatar
im 100% sure they wont fit... they are a couple inches too short...
Old Dec 28, 2009 | 08:08 AM
90veezee3's Avatar
alrighty thanks guys, i appreciate the info. better i find out now then after i spend the money
Old Dec 28, 2009 | 09:25 AM
DeathCougar's Avatar
This is incorrect.
The dually trucks used the exact same cab as the Regular cabs, and as such used the exact same doors.
4 door 4Runner doors are interchangeable only with other 4 door 4Runners.
Btw, this topic has been covered several times before:
https://www.yotatech.com/forums/f116...pickup-145846/
https://www.yotatech.com/forums/f116...bility-104406/
Old Dec 29, 2009 | 08:35 PM
What are you talking about...how can a 4 door use the same cab as a 2 door? Single cab p/u doors are slightly longer than front dual cab doors...same goes for 2 door vs 4 door runners.
For the record I am actually running doors from a 4 door surf (4 runner) on my 89' dual cab pickup.
Maybe things are different outside aus?
Old Dec 30, 2009 | 07:07 AM
We don't have double cab trucks in the US. We only got Regular and Extra cab trucks.
You said dually....which in the USA means Dual rear wheels. These were cab/chassis setups, and were all regular cabs. If you meant Double cab (in which case you should have said Double cab, not dually) then yes, you would be correct.
Gotta remember this website is based in America, where all the trucks are boring and IFS lol
westonian18
May 1, 2020 06:38 AM
theking11863
Mar 19, 2016 09:36 PM
defrag4
Jul 31, 2015 10:50 AM
britishdudes2dr
Jul 25, 2015 06:47 AM
Cplmike
Jul 8, 2015 08:47 PM
