- Broken locker pins -- day old Lock Right!!
- 3.slow and exhaust sensors.
- Wheel/Tire help
- Diff Breather on a First Gen
- Exhaust thoughts for after headers...
- oil pan or rear main? and some other stuff
- Few headgasket probs
- did i mess up my caliper??
- No Electrical. Help!
- which suspension?
- Good spot to tap into efi for kill switch...
- Blowing Fuses???
- Where is PCV valve on 95 runner 3.0?
- Pilot Bearing And Head Dowel Special Tools?
- Opinions on bumper guard?
- 4runner shifting troubles
- Craigs List SLO
- 3.0 Cam question
- Buying 94 4runner!!?
- friggen clutch
- Replaced brake pads and now no brakes?
- The 3.0 Hypothesis - if you've had a headgasket fail, read...if you have headers too
- Possibly the death of my 3.0
- Pulling my hair out!!!!
- crazy idea: 1983 fenders on a 1989?!
- just a lil damage...
- 175 miles to a tank?
- Boring at work, so i made this!
- Auto tranny probslems 95 4runner V6
- my 4runner
- Question about map pocket on door panel '90 4Runner
- O2 sensor from dealer $130
- A little more sound
- the Word on back pressure?
- Door speakers
- So I got a new head, but is that all?
- 33x12.5 bfg m/ts on 3.0 4runner good or bad?
- used 4runner help
- Good Deal??
- thoughts on DOA's Crankshafts, pistons n connecting rods
- Bolt for exhast manifold (22re)...?
- TOTALED 87 4Runner
- 22RE Intake/Battery Swap
- MT-90 or MTL
- To those of yall who've done a bob job...
- radiator differences
- is there a special puller..
- Are these Yota Rims or sumpin else.
- oil cooler part id
- Oil in ISR pipe
- Turn signal quit?
- misfire
- Rear end problems
- ISR mod and SMOG
- Can I add tranny fluid through shifter hole?
- 87 worth it?
- clear bumper lens?
- Lets see your 22re intakes.
- 3VZE Woes Part III
- Knock Sensor!!! Please help need some oppinions!!!
- motor going south?
- Disappearing brake fluid???
- Am I Dumb??
- 22re Highway mileage
- stumbling!! i don't know what to do
- Speakers vs. cargo room: pods, boxes or what?
- Celica 22RE oil pan
- timing chain slop..
- BJ Spacer+Cruiser Coil Lift Tire questions
- Overdrive?
- 1JZ powered 2nd-gen
- Sticky windows
- mystery cv noise
- Spare Tire Removal?
- oil pressure problem?
- weird clank! noise from front wheels while in 4WD...
- Very WIERD hesitation/stumbling problem
- My door wont open!!! Help please
- rear window stuck: 88' runner
- Bed Removal
- Changing gears in the front end
- diverter valve removal
- How difficult is it to....
- Engine trouble, loss of power...
- truck won't start
- 1991 4runner engine died
- LCE's charger set up
- 22re valve lifter noise question
- trail damage report
- Clutch click?
- cleaning your trucks
- 95 4Runner whirring noise
- 3.0 to 3.4 swap?s
- need help
- 22RE Exhaust help
- New shocks
- Head Gasket
- Air conditioning intermittent squeal
- Tube Bumper Coloardo
- Spring cleaning equals................
- Where can I get an axle hub?
- 2 probs: throttle stuck wide open. whats that button above the gas pedal for?
- Please Help with my leaking! (pics)
- Advice by picture.
- Upgraded to 31" :D
- extreme turd polishing/2.4L 4cyl 22re
- Timing/ignition issue
- Setting the timing trouble...
- starter problem
- Brake problem
- Aisin Hubs
- Crossover Elimination
- what is required for 33's?
- Interchangable rims
- Oil filter damage-- cause?
- I HATE this noise...and I need your help!
- Best place to get a clutch for my 89 4runner?
- 86 4Runner Tailgate
- Belt Diagram For 3.slow
- Rear Seat Back Carpet Removal
- 2nd Gen Rear Wiper Not "Springing"
- dash wiring question
- Is this truck worth it?
- steering problems
- My problems continue...
- spark plug wire guides
- 33's or 35's?
- trail gear 3" pics (already searched)
- 92 4runner Still Getting Hot
- How do the hoses attach to this compressor
- Check it
- new toyota tacoma 5 lug?
- thoughts on engine cleaning products
- installing gauges, stock or Autometer
- tps problem
- How many o2 sensors on 95 4Runner
- Where is the power antenna relay located?
- Odd idle
- Time for '91 Part-Out, price list?
- Intake plenum
- Tranny Slipping in Forward Gears 3.0 Automatic
- Help!! 3.0 won't start after tuneup...
- Modified 22re Overheating/ odd idling
- Cruise Control wiring at steering wheel (spiral cable)-new switch. Color/function?
- Undoing the neglect
- 91 4 Runner problem
- Front window replacement
- Bay Area lift install
- what kind of power from mods?
- Cruise Control Swap
- Finally got the engine out of my truck!!
- Belt Problems
- how do I adjust sensor for ebrake on 94 pickup
- PreRunner...possible?
- Bilstein price
- 235/75/15 vs. 31's? Much gearing change?
- Head Gasket Questions
- IFS Bearing Replacement
- '94 pickup hard to start and missing on wet days
- Head Gasket Install? 22RE
- transfercase
- timing wont set and hesitation/miss
- my new 88 pickup! lots of Q's
- Brake squeak
- new paint and stripes on my 87 pu!!
- Ready for new exhaust: header pipe?
- Call me a crazy redneck, but...
- Wheel Spacers
- Stumbling?
- Got some $$$$ to spend... Now what to buy?
- aussie vs. lockright
- Removing Emissions?
- 95 4Runner CEL code 25
- 22RE Valve Steam Seals
- Finished mounting OME kit + 33" :)
- So heated
- third member elocker question
- My new center console build.
- 3.0 headgasket recall/warranty
- Baffled
- lets talk about injector cleaning companies
- AC Pump Clutch?
- Crankin' Tha' T-bar.....cons??
- maybe selling my 4runner
- 22RE tuneup procedure
- 4runner console in pickup?
- its missing, what is it?
- 4WD splash guard
- 1 inch bj spacers or 1.5 inch? Help
- A shout out and question about rust
- Pistons and rings? Your comments on these ones....
- Difficulty disengaging 4WD
- Idle Positioning Screw setting
- Tire Sizing ?'s
- Engine Cleanliness
- tikling noise in the front right wheel...help plz.
- Rear Suspension
- FYI: engnbldr.com's SPRING SALE!!! Also Alternator Option...
- Starter works on bench, not in pickup (getting full power)
- t-case oil cooler
- difficult steering?????
- radiator fluid....green or pink? what gives..?
- 22RE won't pass smog after mods
- 22re dyno graph
- another half shaft...
- Roughness under power
- tires. ugh. help
- Bypass load leveler
- Windsheild Wipers keep falling off...
- 95 4wd differential
- 4.88's!
- 89 4Runner Body lift: 3.25" works for me
- Help!
- Which ARB Bumper will fit a '87 4Runner with SAS?
- Need help with soft short b/t 7.5amp Charge fuse and Ground
- rear axle seal?
- 3VZE - Fast Idle Air Valve (Problem and Location)
- Tips or tricks for burping after radiator flush?
- cheapo intake
- Belt tension on the A/C belt - how tight?
- 1986... time for a lift
- tell me what you think
- rear brake line question?
- toyota brand oil filters
- 1st Gen Removable Doors
- carpet carpet
- Won't start - no click, no nothing
- cluster light bulbs
- 1990 4runner 3.0 - what's a convenient 12v switched power source
- Help please with truck issue
- help!! inner spindle bushing too large?
- 22RTE: Coolant in the Oil
- Aux light install question
- Turbo Questions
- O2 sensor related to ping?
- 89 22RE truck erratic idle
- This shouldn't be so hard!!!
- IFS steering box issue
- Turbo vs Non-turbo Timing cover
- Big Thanks to toyota_mdt_tech!
- will this TJM fit a pickup?
- Need help finding source of oil leak
- A340H problems, not for newbies.
- Questions about Weber Throttle Linkage
- 87 4R 200k miles - Should I buy?
- Clutch fork dust cover??
- neutral start switch
- just plain wrong?
- Water Leak help!!
- what should I do?
