Engine trouble, loss of power...
Old Mar 26, 2007 | 07:14 AM
dingo joe's Avatar
Hi everyone, long time listener, first time caller. I've got some trouble with my 92 pickup 5spd with the 22RE motor. The truck starts and runs perfectly when cold, but not long after it has reached normal operating temp the truck will not idle well (rough to the point of stalling) and it will stumble/hesitate on acceleration/load. If I keep on the throttle it usually will come out of the stumble and then accelerate hard. Without a load, in neutral, the engine will rev freely. Recent work includes new cap/rotor, wires, plugs, filters. It has been running perfectly up until yesterday when the trouble started. I've checked the cap for moisture and found none. (it has been raining ALOT). Please tell me there is an easy (cheap) fix
Thanking you in advance,
Dingo Joe...
Old Mar 26, 2007 | 07:21 AM
dingo joe's Avatar
PS - I've also tested for vaccum leaks by spraying brake cleaner around all the lines and I did not detect any surging in the idle. Truck is stock...
Old Mar 28, 2007 | 10:24 AM
dingo joe's Avatar
bump. is this thing on?...
Old Mar 28, 2007 | 10:32 AM
Tacoclimber's Avatar
Hmm... Almost sounds like a fuel delivery issue, like perhaps the filter?
Old Mar 28, 2007 | 10:49 AM
dcg9381's Avatar
02 is something that doesn't come into play until warm and typically active under load..
Old Mar 28, 2007 | 10:55 AM
Good call... didn't even think about that.
Old Mar 28, 2007 | 11:28 AM
Yota Tony's Avatar
Could be a TPS.
Old Mar 30, 2007 | 09:12 AM
dingo joe's Avatar
I like that, warm and underload are important here. Do I need my O2 sensor? I'll do some searches here.
Still open to ideas, THX...
Old Mar 30, 2007 | 09:31 AM
MudHippy's Avatar
EGR valve, could be sticking open or not closing fully. Or, the EGR valve has moisture in it. It will run rough like that if it does, till it sucks it all through. A small vacuum leak might also do the same.
Old Apr 2, 2007 | 09:29 AM
dingo joe's Avatar
OK, so I got under thr truck this weekend and found that the 02 sensor was wrapped up around a frame support instead of being in the exhust pipe like it should. Seems the PO took it out (or it rusted off/out) and put a patch over the pipe.
Now, here's my question, without an 02, how was my truck running perfectly all winter long? i've got a pipe and a new 02 on order and should have it on this coming w/e, with a progress report to follow...
Old Apr 2, 2007 | 12:40 PM
dcg9381's Avatar
Might be that in winter is was cold enough to need the excessive amount of fuel that was being provided.
The real question is why weren't you setting a code? Check engine light on?
Old Apr 3, 2007 | 04:27 AM
dingo joe's Avatar
check engine light only recently started to come on and was imtermittent, I have not had the codes checked...
Old Apr 17, 2007 | 12:03 PM
dingo joe's Avatar
Just put on a new pipe from the header back w/a new O2 sensor. It's running like a top now. I guess it was the change in the weather, warmer, that exposed the lack of an installed O2 and brought on the stumble/hesitation...
bigjstang
Jun 2, 2025 03:56 PM
Sleaker
Aug 26, 2020 06:03 AM
rushw
Jul 18, 2015 01:46 PM
Poncho0206
Jul 10, 2015 06:21 PM
karbin
Jul 5, 2015 11:37 PM
