Oil in ISR pipe
Old Mar 27, 2007 | 04:10 PM
95RunnerSR5's Avatar
Oil in ISR pipe
The other day i replaced a ticking injector and found oil in my ISR tube, i figured it was the PCV valve so i looked and sure enough it was stuck open. I replaced it saturday but now i looked again and there is oil in the intake again. Can someone help me with this problem? its a 3vze with a rebuilt engine around 11k on it so far
edit: the oil is comming from here, it is pumping quite a bit of vapor out of the valve cover. is this normal? if not what can i do to stop it?
Old Mar 28, 2007 | 01:21 PM
JEBSR5's Avatar
Not sure why you haven't gotten any answers, but mine is still using stock setup and it does the same thing. I think they all do it to a certain extent, but I imagine as blow by gets worse the PCV can't handle it all and some gets blown through the drivers side tube. Not sure what elimination of that tube would do, of course putting a filter on top of the valve cover would be needed for it to breathe. It would just go in to the air instead of reburning through intake.
If it wasn't for that tube venting oil, I wouldn't lose the 1/2 quart between oil changes.
Old Mar 28, 2007 | 01:35 PM
ChickenLover's Avatar
It's normal for a little oil to find its way into your intake. I have inline filters on my pcv hoses to help keep the oil flow to a minimum.
Old Mar 28, 2007 | 01:45 PM
JEBSR5's Avatar
Could you post a pic of that so we can shamelessly copy you?
Old Mar 28, 2007 | 02:17 PM
Sure. My set-up is really nothing special. I've seen much better filter set-ups on this board. I simply used 2 cheapo 3/8" fuel filters from kragen. They were about 3 bucks each. I tried to keep them at relatively steep angle, to help prevent oil from pooling in the filter.
For the driver's side, the 3/8" hoses that came with the filters fit tightly inside the original 1/2" hose.
Old Mar 28, 2007 | 02:45 PM
JEBSR5's Avatar
Looks OK to me. I suppose the direction flows toward vacumn source and would sure slow down the oil vapors. I need to replace my PCV hose anyway, hard as a rock and a little short from trimming.
Old Mar 28, 2007 | 03:26 PM
Thanks for the responses guys. Would it be okay to just put a small filter breather on the valve cover and plug the hole in the ISR pipe?
Old Mar 28, 2007 | 03:32 PM
I tried that for a while. The smell of oil (inside the truck) was awful. This might be unrelated, but when I was running open pcv's, I experienced a loss in gas mileage. Which was ultimately corrected by plumbing the pcv lines back into the intake.
I recommend using a cheap inline filter method. Or a home made catch can.
Old Mar 28, 2007 | 07:45 PM
alright, how often will i have to replace those inline filters?
Old Mar 28, 2007 | 07:49 PM
I'm not really sure. I just added the filters a couple weeks ago.
Old Mar 28, 2007 | 07:52 PM
oh ok and it runs better now?
Old Mar 28, 2007 | 07:59 PM
You won't notice any difference in the way it runs. It is simply a way to help keep oil out of the intake.
Old Mar 28, 2007 | 08:05 PM
alright...if i was any more redneck i'd just run a hose from the pcv valve and valve cover to the back next to my exhaust...but fuel line is too expensive
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
94 Newbie
Aug 6, 2015 10:33 AM
calderp
Jul 27, 2015 09:58 AM
hexrain
Jul 12, 2015 01:13 PM
