tires. ugh. help
Old Mar 20, 2007 | 08:07 AM
dijlop's Avatar
tires. ugh. help
alright, im the crazy freak that switched out my wheels for my dads off his nissan maxima, just for the 15 inch rims. i believe they are about 15x8. im lookin for some tires that will fit under my truck on those wheels. havin some difficulty. i plan on crankin the torsion bar up some and puttin on longer shackles b4 i get new tires. what is the maximum height i can stick under there without any problems, not small problems, i mean any problems at all. thanks.
Old Mar 20, 2007 | 09:04 AM
tc's Avatar
tc
Ummm - on a 2WD? Not going to be very big at all, even with the tbars cranked and shackles...
Old Mar 20, 2007 | 10:04 AM
mtrdrms's Avatar
Go with 31's. There is no reason they wont fit.
Old Mar 20, 2007 | 01:12 PM
Robert m's Avatar
31s will NOT fit. you should be able to get away with 215/75 15 which is like a 27'' tire. anything more and you will need a body lift for clearance. on my truck, with the torsion bars cranked up to almost the max and 1.5'' ball joint spacers, running 235/75 15 which equal out to a 29'' tire rubbed ALOT on the back side of the inner fender well with this amount lift. i put on a 2'' body lift and have no more problems with rubbing.
https://www.yotatech.com/forums/show...t=92604&page=2
Old Mar 20, 2007 | 01:59 PM
tc's Avatar
tc
x2 31's will not fit
My '89 2WD had like 7" lift in Fabtech "Ivan Dan" long travel and 31's STILL rubbed.
Old Mar 20, 2007 | 02:18 PM
86toysr5's Avatar
when i was going 2 uti this guy from michigan had a 81 2nd n had 31s
SC2WD's Avatar
Thanks for posting this thread. I will be following also. If anyone has anything to add about the negative gearing consequences of oversized tires on the 2wd, I'd like to hear that also. I'm trying to get a sense of a happy medium that will give me a little more ground clearance without affecting the gearing or cornering too much, as it is an >80% on-road pickup--
Think: rallye-car--daily driver--pick-up hybrid. Thanks all,
Old Mar 20, 2007 | 02:28 PM
CJM's Avatar
CJM
They had much bigger wheel wells actually..
Old Mar 20, 2007 | 07:41 PM
1995HILUX's Avatar
http://www.yokohamatire.com/TireIntr...reID=100&ID=lt
Old Mar 21, 2007 | 04:27 AM
dijlop's Avatar
thanks for the help guys. anyways, i found some nice tires that sound good for my truck 2day. some bf goodrich AT t/o ko i believe. they make them for 14 inch rims and they run about 27inches high. should fit with the t-bar and shackles right? thanks again
Old Mar 21, 2007 | 02:33 PM
Robert m's Avatar
they should fit without a problem. i was looking at those exact tires also but i decided invest in 15'' rims for a wider tire selection now and in the future.
Old Mar 21, 2007 | 06:24 PM
dijlop's Avatar
true that. i have access to the 15 inch rims, but if i can keep my rims and get some nice a/t tires then im down. i love my rims. they sit out wide and they pretty. lol. yep. thanks. i'll see at some point in the future when iv got the moneys.
Old Mar 22, 2007 | 01:18 PM
dijlop's Avatar
one more thing on these tires. if im movin up in size a couple inches (25.9-27) and gettin a couple inches higher all around how much do u think its going to affect my power. cause i rly dont exactly have an unending supply of power comin from my 4cyl 22re. lol.
TheBFA
Feb 15, 2020 06:55 AM
nvwiggins
13
Jun 16, 2016 03:05 PM
kbpickens
Oct 2, 2015 03:37 PM
87SR5justin
Sep 29, 2015 02:45 PM
Toys4parts
Sep 26, 2015 01:56 PM
