is there a special puller..
Old Mar 27, 2007 | 04:31 PM
justinking060310's Avatar
for the rear tail-housing seal on an automatic tranny? or do i just get to pry it out?
Old Mar 27, 2007 | 04:58 PM
JEBSR5's Avatar
Should be able to pry out with about anything, just be careful about scarring. Obviously, they are easier to get out if the shaft wasn't in the way, but I've removed carefully with shaft in.
Old Mar 27, 2007 | 04:59 PM
eric-the-red's Avatar
You can buy a seal puller, like this. They're cheap and work well.
http://www.sjdiscounttools.com/lis56750.html
Or you can just pry it out with a screwdriver.
Old Mar 27, 2007 | 05:00 PM
Brenjen's Avatar
You should be able to pull out the seal, not sure about Toyotas but on most automatic transmissions there is a bushing behind the seal that requires a special puller. Other than that tail shaft bushing I don't think you need a special tool; at least not for any seal I've ever seen. A brass punch & a pry or even a screwdriver will work as long as your careful not to scratch up the surface of what you're trying to seal.
Old Mar 27, 2007 | 05:01 PM
thanks guys, i didnt wanna pry it out and then learn there is a puller
kat
MichaelKLerner
Oct 27, 2015 07:18 PM
Gravel Maker
RuffStuff
Oct 4, 2015 10:26 AM
Odin
Sep 24, 2015 04:38 AM
mxdw88
Sep 20, 2015 03:13 AM
PureTacoma_Tundra
Vendor Advertising
Sep 6, 2015 06:38 AM
