PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 [92] 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Advice on q 93 pickup tranny, hwat should I do?
  2. Correct way to install exhaust gaskets?
  3. Gonna take the yota for a 1497 mile trip!
  4. looking for o/s valves
  5. 22re Timing tensioner HELP!
  6. Locked Up 3.0
  7. 22RE engine rebuild/gasket identification
  8. No clutch pedal movement after clutch change
  9. Spin off Fuel Filter
  10. Pan hard mod.
  11. Truck doesn't want to start :/
  12. 3.0 fuel pump issues;ground or relay
  13. Transmission cracked housing
  14. 3VZE(3.0) Metal Head Gaskets?
  15. Soft brakes and clicking sound
  16. Why is my oil light flickering and 4runner overheating
  17. 22re, head gasket, timing cover job
  18. 22r timing
  19. 93 v6 4runner oil leak
  20. 1986 Toyota 22r Losing Coolant and Smelling Gas
  21. Timing chain: checking for wear, and making sure it’s set up right?
  22. Single wire 02 sensor to heated sensor
  23. Clutch Fork Throw Distance??
  24. lack of power
  25. 95 4x4 pickup xtra,just did head gasket replacement,still losing coolant,still rusty.
  26. I need help with my 86 4Runner's vacuum!
  27. 1988 toyota 4X4 HELP
  28. Pinion Nut - Toyota Can't find the right one
  29. Help need ASAP, 89 3.0 stalling/flooding
  30. broken thermostat bolt
  31. AC hose fitting stripped :(
  32. Fuel rail leaking
  33. incomplete tire carrier??
  34. 3.0 CODE 52 Knock Senor!! Please help
  35. New Tranny + tcase stuck on 4wd
  36. 3.0 Valve seats going bad
  37. crankshaft housing plugs leaking.
  38. 3vze Auto Transfer Case Rattle
  39. Whos running 5:29 Gears!!! :)
  40. 1990 4Runner - What Steering Linkages to Replace?
  41. Such thing as Heavy-Duty Clutch Master Cylinder?
  42. R12 AC Compressor on 95 4Runner
  43. vacuum question please help
  44. VSV help 1989 22re what is what and where the heck is the one for A/C???
  45. Head to timing cover bolt
  46. '87 Pickup - 22R timing procedure
  47. 4 inch lift
  48. 95 4runner 3vze no power over 50 mph very lean trouble shoot
  49. Help! got a hole in my block!
  50. Anyone know the stock fuel pressure of a 1994 3.0L?
  51. 22RE Head bolt stuck...
  52. First 22re rebuild, some questions
  53. Lower Ball Joint
  54. 1990 Pickup 4x2 IFS to 4x4 IFS?
  55. 1993 4runner i clear 35s with no lift?
  56. Name that noise
  57. Rear diff/Drive shaft (Pic & Vid)
  58. VSV elimination 1989 22re what to do w/ wiring after capping ports
  59. smells like ammonia?...
  60. Nonexistant diagnostic code?95 pickup 3.0
  61. Power Steering Pump Rebuild Question 3vze
  62. axle help
  63. Broke bvsv valve now what?
  64. oversized valves into 3vze
  65. Code 52 Knock Sensor...HELPPPPP!!!!!!!!!!
  66. Electric-No power-randomness
  67. Stuck at the shop, no start!!
  68. 3VZE Heads to the machine shop....
  69. 3.0 V6 Conundrum - Blown Head Gasket - Swap Motor or Fix?
  70. Is my 22re biting the bullet?
  71. In the garage and need help
  72. Intermittent A/C Problem
  73. Hard shifter
  74. Rear shocks
  75. another battery/alternator problem
  76. 88 4x4 pickup sr5 original bumper !WANTED!
  77. Wiring help!!
  78. Cat Back kit or custom?
  79. 3VZ-E Modified Heads
  80. 1994, 3.0, auto. Cutting out, wont go over 20ish mph, need help
  81. Aftermarket Headlights Anyone?
  82. engine and transmission swap
  83. A soft brake pedal
  84. why wont my 22re comme out! GRRRRR
  85. Cold start problem, coolant sensor not hooked up!
  86. Dipstick: Level Engine or Level Vehicle
  87. 1986 4x4: radio, cigarette plug, and clock all quit at the same time...please help!
  88. new cylinder head, motor wont spin over
  89. 1st Gen 4Runner stock or aftermarket clean paint jobs!
  90. 87 SR5 p/u Bumper cap end mount
  91. Radio speakers won't work
  92. Anybody ever attach a tow bar to an ARB bumper?
  93. Bed fit
  94. IFS skid plate options with tube bumper
  95. 88 runner rear end sagging
  96. Water outlet stud depth?
  97. runs but the longer it runs the worse it get?
  98. 1988 Pickup Ilding Violently + Puffing Black Soot
  99. EGR bolts on the exhaust manifold (cant reach them)
  100. Radio Wiring Problem, Cigarette Lighter keeps blowing the fuse
  101. Rebuilt T-case/Transmission Suggestions
  102. Help identifying transmission
  103. Bizarre Turbo Bogging and High Oil Pressure Problem
  104. 22RE Exhaust Hiccup?
  105. air filter hissing... 4rnr stalls when diconected...?
  106. '86 22R-E fuel pump not working?!
  107. *Awesome Dash Gauge LED's* LOOK!!
  108. 3vze head rebuild checklist
  109. Engine light on 95 4x4 pickup 3.0
  110. 90 4-runner vacuum issue
  111. Need front and rear bumper plans 89 4runner
  112. bad oil pressure+hydraulic tensioner=broken guides
  113. finished 3.0 head gasket how many cranks to start?
  114. Best head gasket, copper coat? Need advice
  115. Truck won't start - detail inside
  116. 3VZE - Timing Belt Noise
  117. Can you turn your A/C compressor by hand?
  118. New guy with a new toy
  119. Quick Locker swap Question
  120. vacuum problem
  121. Gearing and tire question.
  122. I wish I knew how to post a pic of that part.
  123. Two vacuum line problems.3.0 95 4x4 pickup
  124. 3zve 4runner has ran fine for years. After charging low battery will not start...
  125. '93 runner rear window relay box different? Pic**
  126. 94 4runner 3vze head gasket issues?
  127. when put in reverse guage fuse blows?
  128. ZUK & BJ spacer 1988 toyota pickup
  129. Coolant making idle suck?
  130. How long before a tight valve burns?: Gathering educated opinions
  131. Fj80 lift help!! Asap!
  132. 3.0 v6 owners
  133. Would Gas Mileage Decrease?
  134. 88 4runner a/c removal...?
  135. 88 22re where does his connect?
  136. v6 headers
  137. Steering issue ?'s
  138. rear window on a 89 4runner wont roll up or down
  139. 95 automatic 4runner surges when flooring.
  140. 68 mustang center console with cup holders in my 4runner...
  141. I passed SMOG!
  142. Thermostat or Fan Clutch?
  143. school me on transfer cases:
  144. Remove CV Shaft Assemblies (Pre Load on Wheel Bearings?)
  145. CV boot clamp broken and missing
  146. Wrong Ignitor/Coil for my 3vze?
  147. Floating grounds and electrical load?
  148. 4wd issues 95 4runner
  149. 89 pickup with 22re, high side ac port location?
  150. Setting timing tomorrow 95 pickup 4x4 v-6,3.0.
  151. Ignition problems 1995 4runner
  152. Brake upgrade gone wrong: help needed
  153. Disconnect Cold Start Injector
  154. OEM Alternator?
  155. 3vze - Need to get better mpg's... or sell!
  156. Head gasket and other issues
  157. 1993 4runner 3.0 head gasket
  158. picked up a lifted 91 4runner! i painted the license plate lights red and black...
  159. Crankcase pulley bolt,help.
  160. New 22RE Noise post-road trip (Video Diagnosis plzz)
  161. Center Console MOD / Cupholder MOD
  162. name that part???
  163. Can you identify this sound (youtube link incl)
  164. 88 4Runner "Restoration"
  165. How do I check ignitor on 91 toy v6 4x4?
  166. Front Steering Knuckle...where can a fella get one??
  167. Disconnecting tranny lines from radiator.
  168. Fixin Up the 91!
  169. 93 Military Toyota Pickup
  170. 93 4cyl gear driver Tcase output spline count
  171. Exhaust leaks
  172. seeking 22re timing chain advice?
  173. Extended brake line
  174. What can i do to get more lift
  175. Front Wheel Bearing on 95 4Runner 4x4
  176. Any interest in a ball bearing reinforced IFS idler arm?
  177. changing front windshield
  178. 88 Oil Pressure Sending Unit Confusion
  179. 22re please help hesitates/hard starts
  180. 92 4runner Gas Mileage problem
  181. Power and gas loss
  182. Timing Cover Crack
  183. no spark to plugs
  184. oil deflector and gasket
  185. To remove the Cat Converter or not?
  186. 93 22re timing issue post head gasket repair
  187. 3zve Head Gasket Replacement with No Start
  188. 3.0 no speedometer and rear abs light always on
  189. power steering box rebuild?
  190. SHOW ME PICS 89 - 95 Pickip's an 4runners
  191. 2" rear shock low budget
  192. This Weekend's Carnage
  193. Potential Purchase: 3.0 Noise?
  194. No (fast) cold start idle
  195. Stumbles at certain low rpm speed, bucks terribly
  196. 91 to 93 3vze problems and differences. Help?
  197. my door wont latch
  198. Attn: Auto painters please help
  199. highsteer /steering box angle
  200. Sway Bar bolts busted into frame....
  201. Another BJ Spacer question...
  202. Squirrely SAS truck
  203. sas shackel angle help
  204. FJ Rims on 1st Gen 4Runner
  205. think I may have a blown head gasket
  206. think I may have a blown head gasket
  207. 3.0 dies/stalls when turned to the right????
  208. oil gauge not working stuck at high pressure please help
  209. ifs pitman arm removal for sas
  210. I wonder how these would look?
  211. How many friends do I need to bring?
  212. How many friends do I need to help?
  213. '90 4runner wont stay in O/D
  214. 89 Yota 4x4 want start or run on its own! Please help!
  215. fuel pump 87 pickup whoo,s
  216. Just drove the 88 4runner from Florida to Connecticut
  217. Confused about fuel - ethanol vs octane 94 22re
  218. Cannot find Aisin Clutch kit
  219. Shaky shaky...
  220. Which sensor to replace?
  221. Cold start o2's and more
  222. extra steps to keep a 22re cool?
  223. Hasaki Timing set, Don't BUY
  224. 3VZE - Lubricate Speedometer Cable
  225. 22re wont throttle up
  226. No Power Steering. (Searched the best i can before posting)
  227. truck running rough after not running at all
  228. 87 4x4 needs rotors help
  229. 22RE OR 4.3 GM Motor
  230. Tips & Tricks- 4" bracket lift!
  231. Timing off after installing crank pulley bolt...
  232. Slight overheating - New fan clutch?
  233. Help! 86 with new engine and temp problems
  234. 1995 pickup 4X4 Rad fan noise
  235. Tire Rack Ideas on a Trail-Gear Rock Defense rear bumper??
  236. 93 4runner - blown head gasket
  237. 22RE - Factory Cruise Control Setup
  238. Starting head gasket replacement right now.
  239. 1990 4runner starting issues
  240. 1992 Truck help needed
  241. Tell me where to find the clunking
  242. 93 pickup 4x4 rotor job
  243. My '87 Escaped into the wetlands (Pic enclosed)
  244. Help me with this diagram, what timing cover do I have??
  245. scolding hot radiator
  246. Air intake tube?
  247. 22RE Head gasket Failure, Perhaps this will shed some light on WHY
  248. Timing problem (3.0)
  249. IFS third member install - need help
  250. Rear coil springs shot - I need advice
