oversized valves into 3vze
Old Jul 6, 2012 | 10:16 PM
BirdDogg's Avatar
I'm doing a head job in near future, and thinking of going with larger valves... Probably just 1mm. Has anyone done this, or recommend valves to go with?
Also, I believe ill need shims? ...Will I need to know what size shims to buy, or do they come in a kit?
And how about springs?
3vie
Old Jul 7, 2012 | 12:21 AM
abecedarian's Avatar
as for valves, you're limited by what size seat can be cut into the head, or if your seat can be cut to accomodate larger valves, and such. 1mm should be okay but I suggest talking with an expert, for instance talk with engnbldr.com. larger valves could push you into having an "interference engine" and should the cam belt slip or break you may end up with major damage.
shims are going to depend on the cam and how the valves sit, as in there is no "kit" for a new head / valves / cam. Everything has to be put together, measured and then what shims are needed are installed. no cookie cutter thing. you might even have to change shims 2-3 times before everything measures out.
JHalcyonM
Mar 6, 2019 08:37 AM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
ManzDaKlown24
Aug 22, 2015 10:25 PM
ethanethan
Engine Swaps
Aug 11, 2015 09:09 AM
