3VZE Major Tune Up
Old Aug 15, 2015 | 08:36 PM
JHalcyonM's Avatar
Post 3VZE Major Tune Up
Alright... first things first. Please keep the 3.slow comments away. I know the debate. I love both for different reasons. So THAT's out of the way! Question is this... What are the main requirements for a major tune-up. Im at 150,000 miles and I would like to do most, if not all, of this by myself. I understand the basics, but it would be helpful to hear 3VZE specifics. Also, what brands to stay away from and what brands to stick to on certain things. My 3VZE seems to idle high on start up and sounds very choppy, as if it is missing, but the plugs tell me it isn't missing. I would like to take this opportunity to do a major tune up. So reply away.
1989 Toyota SR5 V6 Ext. Cab... and sadly its an auto (I'm swapping it pretty soon)
Old Aug 15, 2015 | 08:45 PM
scope103's Avatar
Do you have this: http://personal.utulsa.edu/~nathan-b...e/64tuneup.pdf ?
And this: http://personal.utulsa.edu/~nathan-b.../1maintena.pdf ?
Old Aug 15, 2015 | 08:50 PM
JHalcyonM's Avatar
ill be damn, i didnt know they had PDF for it all. thanks man.
Old Aug 16, 2015 | 06:45 AM
scope103's Avatar
I consider the FSM to be the last word on these matters, but where they call for Special Service Tools it's worth doing a search here. For instance, if you want to change the timing belt you need to remove the crank bolt (and put it back!). There's an SST to keep the crank from turning as you try to remove the bolt, but you'll be better off building your own. (e.g., https://www.yotatech.com/forums/f116...h-3vze-137934/ , but this is only one of several good ones)
Old Aug 16, 2015 | 09:56 AM
Terrys87's Avatar
I get my fuel filter from the local part store, my Denso wires off of ebay for about $25 and that includes shipping. Everything else common to tune up (plugs, cap, rotor, oil filter) I get from the dealer. They are not as high priced as most may think. Best quality parts that you can get and in some cases cheaper or same price as part stores top shelf brand.
Even with top shelf brand cap and plugs, I have had the wires work out of the cap. Never once I have I experienced that with Denso.
Old Aug 16, 2015 | 11:10 PM
JHalcyonM's Avatar
Thanks guy. But i have heard (other forums/videos that you don't have to take that "hulk bolt" out... To change the timing belt. I love it when people build there own tools though. Smooth move.
Old Aug 17, 2015 | 09:57 AM
Janos01's Avatar
In addition to what Terrys87 mentioned, replace fuel filter I use a WIX one, and if possible drop the pan and change the transmission filter.
Regarding your ruff idle, the injectors my need a good cleaning with some Lucas or Chevron w Techron. Also does any white smoke come out the pipe when its cold?
Old Aug 17, 2015 | 10:06 AM
JHalcyonM's Avatar
Well i have already changed the fuel filter (removed bed, way easier IMHO). The truck blows white smoke out he back at first start up and sometimes it continues for an extended period. It is very humid here in MS so maybe condensation and moisture is causing that but it seems... excessive. I have already replaced the O2 sensor too so thats not it. And there are zero bubbles coming up in my radiator. Sooooo idk what the deal is about the white smoke. It smells bad too. A little bit gassy, pun intended. It seems to happen even after the engine has been previously pretty warm.
Old Aug 17, 2015 | 10:16 AM
scope103's Avatar
Stick your hand in the exhaust. If it comes away oily, the white smoke is probably oil. If it comes away damp, smell it. Does it smell like anti-freeze? Then it could be coolant.
If your hand comes away wet but doesn't smell like anything in particular, that's normal (at least soon after startup).
Old Aug 17, 2015 | 01:59 PM
JHalcyonM's Avatar
Well its got a bit of an odd sweet smell to it. And my hand gets extremely wet just about instantly. The smoke goes away after i drive it a while but I've tried to just sit in the driveway and let it run until i cant see smoke but I've ended up sitting for probably about ten minutes and it still smokes.
Old Sep 26, 2015 | 04:23 PM
cdd408's Avatar
[QUOTE=JHalcyonM;52284983]Well its got a bit of an odd sweet smell to it. And my hand gets extremely wet just about instantly.
we still talking about cars
Old Sep 26, 2015 | 06:07 PM
GO_BLUE!'s Avatar
.... but enough about your sister. LOL!
I am at 149K and just replaced the plugs, cap, wires, rotor, and I ordered & installed a set of Flamethrower injectors. I cleaned the gunk out of the intake & throttle body while I was there, using Easy-Off oven cleaner. New PCV & valve cover gaskets. Timing is advanced just a tad.. 13-15-ish. And I seafoamed it. night v. day difference. Definitely DENSO. Amsoil 10w-30 Z-rod oil with the extra zinc. New Oil, Air & Fuel filters. New-ish Tranny filter & Amsoil synthetic tranny fluid. And i greased the driveline using Lucas Red. New Toyo Open Country A/T II tires this week. New-ish Bilsteins all around. She's runs as smooth as a fat chick on ice. But enough about your sister :p
Old Sep 26, 2015 | 07:04 PM
cdd408's Avatar
LOL
GO BLUE! you live in San Jose, I live in the evergreen area. When I get my 1st gen running should go to hollister hills
Old Sep 28, 2015 | 05:30 AM
AKHeathen's Avatar
start with a hot chemical flush.... of everything, lol..... really, though, the oil system, chemical flush it before oil change. trans flush, power steering. you want to knock everything built-up off and than get rid of it. including changing the brake (if applicable clutch too) fluid and radiator..... i hear the belt should only go like 80k, though mine is twice that, as yours probably is. i think it's more like a time thing, as you can have a 15 year old belt be in the same condition at 10 miles ans a 10 year old belt at 150,000 miles... either way, if you don't know it's been changed at east this decade, probably should get it done now..... and of course, all the gear fluids and greasing. check free-play on the ring and pinions first. and all suspension components. at my old job, it was called a "c-service" every 50k and we would tear down all the diffs and planetaries (complicated hubs) and etc, and at least change all fluids....
Old Mar 4, 2019 | 08:04 PM
snoWStomper85's Avatar
Have a 91’ 3vze 4Runner and I am right around 155k and got the hair also so I brought it in the shop and did full EGR/pair delete along with all hard lines gone away with! I put some iridium NGK plus and some like $60 NGK wires in! I also got a cold air intake lol just a cheaply to see, works great (eBay) new high flow fuel pump and new fuel pump relay! Oh and this thing called The Fuel Maxximizer! Idk it was like 20$ and claimed 35 more horses! And oils and radiator flush and new coolant! But I’m gonna tell yeah I have had a suuped up 3.4 that people thought was turbo charged cause of the injectors and intake and chip but honestly my Runner is a completely new machine way more power sound and just throttle response! All in all problem into it $350 and quite a few hours but it’s dam cold up here in Idaho and I am by no means a mechanic! Oh seafoamed the intake plhuemal i did valve cover gaskets and plemal gaskets too but that was just caus I didn’t know what I was doing and got to deep! Lol so 3. Slow no more!!!!
Old Mar 5, 2019 | 10:47 AM
Kolton5543's Avatar
A little late again. You should start checking the dates of threads prior to commenting on them. That fuel maxximizer thing, throw it in the trash. It's fake, and will likely cause issues down the road.
Old Mar 5, 2019 | 04:35 PM
NYHumpinUtah's Avatar
Hey scope103, you have an updated link for these sites? Now I am an owner of a 3VZE engine and would like to read up on it
Thanks
Hump
Old Mar 5, 2019 | 06:51 PM
scope103's Avatar
http://web.archive.org/web/201208120...buchanan/93fsm
Old Mar 6, 2019 | 08:37 AM
Thanks scope103
Very helpful!
ladybugRC
458
Aug 21, 2020 10:41 AM
91yotapup
3.4 Swaps
Mar 5, 2019 10:41 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
the_supernerd
Oct 1, 2015 09:20 PM
