IFS third member install - need help
Old Jun 21, 2012 | 09:46 AM
4runninmuds's Avatar
Sorry if there is a thread about this already somewhere, if so, could you direct me to it?? Thanks
Ok fellas, I've been searching everywhere for some tricks and ideas on how to get the CVs onto their respective studs. Just in general I need help with ways of making this go smoother. It's HEAVY heavy and awkward and I'm hoping you dudes have some tricks to make this easier. If the trick is to take it to a mechanic haha I'll accept that.
Cheers guys
Appreciate any input you have
Kael Klein
Old Jun 21, 2012 | 09:57 AM
BMcEL's Avatar
Drive the studs out or disconnect the lower ball joint from the knuckle. Try searching.
Old Jun 21, 2012 | 10:58 AM
Clearly stated I have been searching and I still am as well.
Old Jun 21, 2012 | 10:59 AM
Thanks for the ideas though, have you ever hammered the studs out before or heard how difficult it is? Would it cause damage?
Old Jun 21, 2012 | 11:59 AM
BMcEL's Avatar
Yes you can damage the studs if you aren't careful. I leave them in place and disconnect the lower ball joints. Much easier.
Really?
https://www.yotatech.com/forums/f116...ctures-158106/
https://www.yotatech.com/forums/f116...ng-off-176999/
https://www.yotatech.com/forums/f116...runner-253342/
https://www.yotatech.com/forums/f116...emoval-245957/
https://www.yotatech.com/forums/f116...diy-no-184815/
https://www.yotatech.com/forums/f116...cement-190658/
https://www.yotatech.com/forums/f116...cement-194671/
https://www.yotatech.com/forums/f116...estion-180797/
https://www.yotatech.com/forums/f116...v-boot-156096/
https://www.yotatech.com/forums/f116...-axles-147580/
https://www.yotatech.com/forums/f116...cement-121070/
https://www.yotatech.com/forums/f116...runner-130305/
Old Jun 21, 2012 | 12:07 PM
angrybob's Avatar
I removed 4 studs on each side and replaced with bolts...for the *next* removal They can be driven out a couple different ways:
1. Air hammer with a dull point tip. Pushed them out like butter - this is the method I used with the shafts still installed into the 3rd member.
2. BFH and leave the nut on the end upside down and a few threads above the edge of the stud. You strike the flat side of the nut vs. the stud itself. Preserves the threads more. Still, when doing this use your head. This is the method I used with the shafts out of the 3rd member as loose parts.
Old Jun 21, 2012 | 12:47 PM
BMcEL I think you are mistaking my lack of ability to navigate the site for not looking. I'm not computer savvy and I really appreciate your help. Cheers!
Angrybob that is great advice, thank you
Old Jun 21, 2012 | 01:03 PM
Angrybob can I use the BFH method with the shaft still attached to the third or is there another risk there?
Old Jun 21, 2012 | 02:29 PM
nightstalker's Avatar
I took the lower ball joint out and disconnected the shock on bottom, it works well. P.s
.... leave the warn hubs in ur room. Asins r better. Jmo
Old Jun 21, 2012 | 02:37 PM
Warns already onnn, I heard they were good though, and lifetime warranty speaks for itself. Thanks for the input sir
Old Jun 21, 2012 | 04:09 PM
Stuwy123's Avatar
Put the nuts on the end of the studs before hammering them! (So much pun).
The studs hammer out easily, just don't grind down the splines like some threads say.
They are easy to line up again.
Removing the studs makes installing the IFS diff almost a one person job. Almost.
Old Jun 21, 2012 | 04:11 PM
Just did exactly as you said as you said it haha, and I am indeed about 1/4 of a person short of getting this in myself...I guess I'll go ask my girlfriend for help. :O haha
Old Jun 21, 2012 | 05:31 PM
ChefYota4x4's Avatar
Wait, .... so that guy who told me to head butt it was lying????????? hahahaha
All the info you need here... And I did a write up on it as well(not sure if it's one of those links that my bud BMcel posted up, haha)..... Suckers are heavy, aint they? They'll flatten a finger or 3! ....and HAVE, as I've seen happen at the pick-your-part .... WOW that was disturbing to see!
Best wishes,.... and YES, put the GF to work, I agree!
Old Jun 21, 2012 | 05:46 PM
I realize why I couldn't find any of these great links...They don't have anything to do with installing a whole assembled ifs third member and getting the studs up past the cv shafts. Thanks though.
Old Jun 21, 2012 | 05:51 PM
That came out condescending for some reason, BMcEL, your links were very close to what I need but funny enough your idea about knocking the studs out worked wonders! All fingers attached still!
Chefyota - I've seen you around here a lot! Pleasure to "meet" ya! Haha mostly seen you on that couples journey to south America I believe, and your build thread. Amazing isn't it!
Cheers from Vancouver, Canada
Thanks again for all the help fellas
icentropy
Sep 16, 2020 02:47 PM
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
scottyg486
Jul 19, 2015 05:34 PM
bryan34w
Jul 6, 2015 05:53 PM
