cv axel not coming off
Old Mar 17, 2009 | 09:13 AM
jonwest7's Avatar
Question cv axel not coming off
`94 4Runner. I'm having troubles removing the cv form the 6 drive axel bolts. Only need another .5 cm and it's free. Any tricks?
Freewheel hub body is off. ?Does the Large hub nut need to removed as well as other stuff? Suspension linkage removel? Pry bar and buddy?
Old Mar 17, 2009 | 09:55 AM
scuba's Avatar
I suppose you may have missed the snap ring..?
http://personal.utulsa.edu/~nathan-b...18frontdri.pdf
Old Mar 17, 2009 | 10:50 AM
Matt16's Avatar
Here you go:
From https://www.yotatech.com/newreply.ph...ly&p=50938697:
Originally Posted by Matt16
Well my inner CV boot was spitting grease and it was getting worse after every time I locked the hubs. I replaced the boots with Beck-Arnley replacement boots. Toyota boots were hideously expensive. The whole job took about 4 hrs with breaks rain, and a tire rotation etc.
Removing the CV axle
  1. Park truck on flat level ground, set parking brake well and chock the wheels either side of the axle your working on.
  2. Unbolt the CV- diff flange. I had already removed the studs when the diff was on my driveway pre-install.
  3. Remove tire and the hub. To do this, remove the front hub cover (dial in centre) undo the brass- coloured bolt/washer in the centre of the axle. Cone washers are removed by beating on the hub directly above the cone washer. Its a pain.
  4. I disconnected my swaybar as I have quick disconnects, but not sure if its necessary to be honest, but its easier to unbolt the opposite side now, then later.
  5. Remove the C-clip and splined washer beneath the hub
  6. Now, go around to the back of the truck and jack up the wheel diagonally opposed to the CV you're working on
  7. Go back to the front and place jack under the lower ball joint. You're trying to compress the suspension so that the outer CV doesn't catch on the lower A-arm.
  8. Undo the bolt connecting the shock to the LCA (lower control arm)
  9. CV should slide out. Watch that the swaybar endlink doesn't tear the outer CV boot.
Replacing the CV boot
  1. Break the clamps (metal bands) holding the boot to the axle
  2. Slit the boot and remove, with as much of the grease as possible. DO NOT pull the tripod out of the socket yet.
  3. Wipe out the old grease with paper towel, took me about a quarter of a roll. DO NOT use parts cleaner, the residue is incompatible with the grease and boot. Just get as much as possible with paper towels.
  4. Match mark the tripod joint to the inner CV socket, so that each of the three lobes goes back into its original place. This is a bearing actually, so this stuff does matter.
  5. Pull the tripod joint out of the socket after matchmarking.
  6. Clean off the end of the tripod joint well enough to match mark the splined shaft to the tripod itself.
  7. Remove the C-clip and pull the tripod joint off the splined shaft.
  8. Slide the small clamp, then CV boot over the axle, so that the boots sits on in the grove on the shaft. This is obvious when do it. Slip the clamp over the end of the boots and pull tight with pliers, maybe 5lbs pull. Fold the tag end over close the fingers. Should be obvious when doing it.
  9. Coat the socket and bearing surfaces of the tripod joint with the grease provided with the boots. Eat the rest of the foul grease in one swallow. The package says you should worry if TWO mouthfuls are swallowed, thus one mouthful should be fine. It actually says this.
  10. Put ever the axle back together making sure to line up the match marks. Clamp the outer boot in place AFTER letting some of the air out of the joint. I just guessed on this part by looking at it. Basically, there shouldn't be too much air in the boot.
Assembly is reverse removal.
Link for more IFS maintenance. This writeup also has pictures of the stuff I am describing.
Old Mar 17, 2009 | 10:59 AM
toyospearo's Avatar
Here's one with PICTURES!
https://www.yotatech.com/forums/f116...ctures-158106/
Old Mar 17, 2009 | 11:24 AM
GSGALLANT's Avatar
If the problem is you can't get the differential end of the CV axle to clear those six studs, you can do one of two things.
Either pound out two of the six studs (they are just pressed in there), or remove the four lower balljoint bolts so that you can swing the bottom end of the spindle outwards (use blue loctite on these bolts when you put them back on). Either of these two methods will give you the clearance that you need to get the CV out.
Old Mar 17, 2009 | 02:24 PM
iamsuperbleeder's Avatar
torch through the center shaft it's trashed anyhow, right? or are you just replacing boots...
Old Mar 17, 2009 | 02:34 PM
874runnersr5's Avatar
haha, is it like this
Old Mar 17, 2009 | 02:44 PM
how did you manage to push the cover off it like that?
Old Mar 17, 2009 | 03:06 PM
abecedarian's Avatar
unbolt the upper ball joint from the control arm and pull the spindle outwards.
... done....
Old Mar 17, 2009 | 03:19 PM
GSGALLANT's Avatar
...a little more... if I can just compress it another 1/4", I'll have it... ahh crap!!! That happened to me the first time. Since then, I've unbolted the lower balljoint to remove CV axles.
Old Mar 17, 2009 | 03:20 PM
oh does the joint press against it from inside and pop it out? lol, that's gotta be messy...
Old Mar 17, 2009 | 04:39 PM
haha yeah it was super messy, no idea that cv joint was junk. it blew apart lol
Old Mar 18, 2009 | 08:20 AM
scope103's Avatar
To remove the 1/2 axle (carrying the CV joint) you must make sure that the front springs are compressed as though the truck were sitting on the ground. If the front suspension is just "hanging" (with a jack stand on the frame, for instance), you will never get it out -- the angles are wrong.
I have no trouble with just sitting the hub on a jack stand, but the point of putting a jack on the opposite corner (and lifting a little) is to get just a wee more compression on the front spring. So you might want to try that if my method alone doesn't quite do it.
You will hear from others on this site who have removed ball joints, shocks and even pounded the studs out of the differential flange. You don't need to do any of that.
Old Mar 18, 2009 | 09:09 AM
tommy316's Avatar
When I was installing my front locker, my truck was on a lift and had to remove the front diff. When installing it, had to fight vs both CVs to get them to line up right and slide in, just about the opposite of that, it took 3 guys to finally get that back in there. Lots of wiggling and shimmying around.
Old Mar 18, 2009 | 10:56 AM
GSGALLANT's Avatar
I prefer to have my truck firmly planted with jackstands on the frame when I'm crawling under it. Not with most of the weight supported at two opposite corners of the vehicle. To each their own, I guess, but four balljoint bolts take 5 minutes to remove/re-install.
Old Mar 18, 2009 | 11:31 AM
Yeah, i found that removing the shock, and jacking up the a-arm side that you are doing the cv on helps alot to.
jasonty
41
Dec 23, 2018 01:00 PM
itzmywife's
Jul 25, 2015 04:55 PM
ripp96
Jul 25, 2015 02:32 PM
keithporter83
Jul 18, 2015 12:37 PM
Odin
Jul 15, 2015 09:28 PM
