In the garage and need help
Old Jul 6, 2012 | 10:29 AM
Hilux4Life's Avatar
Hey guys I feel like such a noob for asking for help with this, but I am about to loose it. It's over 100 degrees and I have been trying to remove my hub for the last 2 hours. I need to put on some new rotors. I have the cone washers out now, but for the life of me I can't find the lock washer that is holding everything in place. I have seen you tube videos and I can see it on the dudes truck but not mine. It is like the washer is not even there, but the hub will still not come off. I have seen several write ups on this but they all just kinda skip over this step. Their instructions often say remove the hub. Can anyone point me in the right direction?
Thanks!!!!!!!
Old Jul 6, 2012 | 10:39 AM
BMcEL's Avatar
http://ncttora.com/fsm/
Old Jul 6, 2012 | 10:52 AM
waskillywabbit's Avatar
Model and year?
Auto hubs?
:wabbit2:
Old Jul 6, 2012 | 10:55 AM
Hilux4Life's Avatar
Thanks I already have the fsm. It says the hub should just pop off after the nut and washer is removed, but that's not happening no matter how hard I hit it with a rubber mallet.
Old Jul 6, 2012 | 10:56 AM
Hilux4Life's Avatar
˟˟˟˟ sorry. 1992 manual hubs. Hold on let me take a photo
Old Jul 6, 2012 | 11:11 AM
Hilux4Life's Avatar
Oops hold on
Old Jul 6, 2012 | 11:13 AM
Gold bolt with washer in end of axle shaft or C clip on axle removed?
:wabbit2:
Hilux4Life's Avatar
Hilux4Life's Avatar
Yeah it's removed
Old Jul 6, 2012 | 11:17 AM
Probably just stuck from years being on there. Try brass drift and 3 lb sledge.
Gasket or RTVd on there or can you tell?
:wabbit2:
Old Jul 6, 2012 | 11:20 AM
Hilux4Life's Avatar
Hard to tell. I think it's a gasket.
Damn thing just won't budge. I will keep swinging away.
Old Jul 6, 2012 | 11:59 AM
wyoming9's Avatar
Red face
Small chisel and just tap around the seam where the free wheeling hub joins the axle hub.
The first time in a few years they can be a real bugger.:wabbit2:
Kroil works wonders
Now might be a good time to pull the caliper off.
Old Jul 6, 2012 | 12:21 PM
Hilux4Life's Avatar
Update. It came off finally. Thanks for your help wackily. Just wanted to make sure I was not going crazy. However I did find this and I am sure this is not good. [IMG][IMG][IMG]
[/IMG][/IMG][/IMG]
Old Jul 6, 2012 | 12:22 PM
Hilux4Life's Avatar
Old Jul 6, 2012 | 01:08 PM
I see you finally hit it with your purse
Knuckle service kit will replace all those parts.
The star washer is supposed to be bent like that. One tab over the inside 54mm nut, one tab over the outside 54mm nut so they don't back off.
:wabbit2:
Old Jul 6, 2012 | 02:24 PM
Hilux4Life's Avatar
Ok thanks that clears things up. I came across another issue. I always heard that you should replace the inner bearing seal when you do this job. Thats actually what the write up on 4x4wire I am using says to do. Well a long time ago my dumbass ordered the wrong part, which of course I find out today. I have marlin crawler inner axle seals. Naturally, I called three Toyota dealerships and I can only find one inner bearing seal. Of course they charge full price. I have a dealer in ga that I usually use because he charges way less, but that means i would get the parts much later in the week. That is no bueno when this is my DD and it's sitting on jacks.
So if I get a seal puller would I be able to pull the inner seal and reuse it? Everything internally looks to be in great shape. Gotta love a Toyota.
Old Jul 7, 2012 | 05:00 AM
Hilux4Life's Avatar
Sorry to bump this, just wanted to see if anyone can answer if the inner bearing seals can be reused or not.
Thanks
Old Jul 7, 2012 | 05:52 AM
You pull the seals and they will be junk.
:wabbit2:
Old Jul 7, 2012 | 06:28 AM
Hilux4Life's Avatar
Thanks for letting me know. Looks like I can only source one inner seal right now so looks like I will have to do this project next weekend. For now I will just put everything back together.
Are there any other things that I should replace while in am in there besides the inner seals and gaskets for the hub?
The bearings looked like they were brand new so I think I am good there.
Thanks for your help guys
Old Jul 7, 2012 | 11:39 AM
wyoming9's Avatar
Red face
If you got the hubs off without ruining the seals and your not repacking the inner bearing I have gone through 2 sets of brakes on the same seals
if you pull out the seals you should repack the inner bearings sort of the only reason to remove a seal unless it is leaking.
You do have the correct or makeshift tools for installing the seals not that your left hanging again.
