Another BJ Spacer question...
Old Jun 25, 2012 | 10:35 AM
MRC3's Avatar
Does anyone make BJ spacers that do NOT require you to cut/grind the UCA? Or can the BJ spacers be ground to work without messing with the UCA?
Old Jun 25, 2012 | 10:42 AM
waskillywabbit's Avatar
Not that I've ever seen.
:wabbit2:
Old Jun 25, 2012 | 12:49 PM
highonpottery's Avatar
due to the contact patch needed to fully mate up and support your ball joint, the spacers kinda have to be the size they are. done correctly, you're not really cutting off enough material to significantly compromise the structural aspects of the a-arm. for normal DD or light-medium offroading you will be ok. if you plan to wheel your rig any harder than this or pre-run/jump your rig, then you most likely won't be worrying about any of this because stock IFS components just aren't gonna work for those situations.
Old Jun 26, 2012 | 07:54 AM
arlindsay1992's Avatar
It might seem difficult to stomach the idea of cutting parts off of your suspension, but it's not a high stress part you're removing, it's not easily seen if you decide to revert to stock, and all the cool kids are doing it. Get out the grinder.
Old Jun 26, 2012 | 07:59 AM
MaK92-4RnR's Avatar
You're cutting a sliver off your upper control arm... Nothing bad is going to happen.
Old Jun 26, 2012 | 08:01 AM
If you zoom in a bit, you can see how little is actually removed to allow clearance for the BJ spacers.
https://i.imgur.com/EsWGe.jpg
https://i.imgur.com/cxsKM.jpg
Old Jun 26, 2012 | 08:08 AM
MRC3's Avatar
Thanks for the pics. It makes sense now. I was thinking that the grinding was done on the FRONT of the UCA not the back.
I can see some BJ spacers in my future.
I appreciate the responses guys!
Old Jun 26, 2012 | 08:30 AM
BlazeN8's Avatar
Have you read this thread? https://www.yotatech.com/forums/f120...runner-250313/ I touched on a number of issues that might be of interest.
Old Jun 26, 2012 | 10:35 AM
BMcEL's Avatar
^ Good link Nate!
4x4YOTA
Aug 23, 2016 09:08 AM
89YodaRunner
Sep 30, 2015 02:18 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
4runnerFireman
Sep 29, 2015 06:24 AM
crash813
Sep 27, 2015 07:15 AM
