Help! 86 with new engine and temp problems
Old Jun 22, 2012 | 07:32 PM
86expo's Avatar
New to forum and 4runners. I picked up a nice 86 SR5 with blown motor. I ordered a motor from davezoffroadperformance. I took radiator to have it flushed and checked when I pulled old motor. Tried to do everything right from the start with new injectors pulleys alternator and electric fan system. Anyway the motor starts and runs great. At idle temp stays close to 195 mark. After I drive for 15 or 20 minutes temp will be up to 220 and still wanting to rise. I have tried to keep from getting to hot but I need some help. Tried new thermostat today and same problem. Need some help or ideas
Old Jun 22, 2012 | 07:44 PM
Teuf's Avatar
Hi 86, welcome. try the dual stage thermo and or a new sensor.....
Old Jun 22, 2012 | 08:46 PM
86expo's Avatar
I installed new temp gauge today. Still hot. Im going to order a dual stage thermostat. I drilled two 1/8" holes in thermostat to see if it made a change and it didn't help.
Thanks for the input
Old Jun 22, 2012 | 09:00 PM
Luvmeye22re's Avatar
How did you burp it? New water pump?
Old Jun 23, 2012 | 05:17 AM
86expo's Avatar
Water pump is new. I've tried to burp it several ways. Front end on curb with radiator cap off for several times. I saw lots of air come out
Old Jun 23, 2012 | 06:41 AM
Buck87's Avatar
Does not sound like the common temp spike issue. Does it get hot when you are on the highway or freeway or just when you are not moving or in traffic?
Old Jun 23, 2012 | 06:46 AM
Buck87's Avatar
Just reread original post and it said that the temp stays around 195 at Idle.
Yota.Jay
Jul 23, 2015 08:08 PM
Avenged
Jul 9, 2015 07:55 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
wilbertd
Jul 6, 2015 07:39 AM
