Pan hard mod.
Old Jul 11, 2012 | 09:19 PM
Jared7467's Avatar
Pan hard mod.
I was thinking instead of doing a panhard drop I could leave the mount higher and just have a tie rod with Hyme joints on it to center my rear axle on my 91 4 runner. Any thoughts of why this would not work?
Thanks you guys are the best,
Jared
Old Jul 11, 2012 | 09:43 PM
TrikeKid's Avatar
Panhards work best when they are parallel with the axle, that's why you drop them, not just because of length.
Old Jul 11, 2012 | 10:28 PM
abecedarian's Avatar
Yep. Heim joints won't compensate for the fact that under certain circumstances the axle will be pushed or pulled from the centerline of the frame with a panhard setup.
Old Jul 15, 2012 | 05:39 AM
Fraser's Avatar
The best setup would include a drop bracket AND adjustable bar.
That way the angle would be kosher and you could adjust the length to perfectly center the axle.
Old Jul 15, 2012 | 06:58 AM
Red Wagon's Avatar
When I get home from the mine I am installing my pan hard drop bracket from 4crawler.
Not having one in bent my sway bar links and at full droop my driveshaft is mere millimetres from the gas tank armour.
Might as well grab disconnects while your at it.
Old Jul 15, 2012 | 08:12 AM
Actually, the best setup is Watt's Linkage.
Old Jul 15, 2012 | 09:50 AM
Red Wagon's Avatar
That looks interesting. Is that custom made?
Old Jul 16, 2012 | 08:49 PM
Well, it would be custom on a 'yota, but it's been around a while.
http://en.wikipedia.org/wiki/Watt%27s_linkage
Old Jul 17, 2012 | 03:02 AM
Red Wagon's Avatar
I like the animation.
Thanks buddy. First time I've heard about one of these.
Old Jul 17, 2012 | 05:42 PM
They've been around a while but are more expensive to implement than a panhard.
The animation was grabbed from wikipedia and shows how it works superimposed on some Ford thingamajobber.
he's gone
7
Dec 3, 2019 07:08 AM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
BigMike
Marlin Crawler
Sep 3, 2015 07:49 PM
falcon4runner
3.4 Swaps
Aug 6, 2015 02:36 PM
irritech
Jul 27, 2015 05:15 PM
