lack of power
Old Jul 10, 2012 | 08:00 PM
reubenhayden's Avatar
lack of power
I have a 90 4-runner 3.0 motor. At light throttle or when accelerating it acts like its bogging down. Once I get to just before quarter throttle it clears out and runs with power. Just replaced cap, rotor, wires, plugs, and checked for vacuum leaks. It also has new air cleaner and ran injecter cleaner through it. Doesn't seem to change. Anyone have any other ideas. Thanks
Old Jul 10, 2012 | 08:26 PM
PowerstrokeJoe's Avatar
Have you checked your timing? What about your AFM? Both of those can equate to low power.
Old Jul 10, 2012 | 08:31 PM
Ya the timing is right on haven't checked the afm. What does that intell?
Old Jul 10, 2012 | 09:42 PM
abecedarian's Avatar
How did you check the timing?
What did you set it to?
Old Jul 11, 2012 | 04:50 AM
INFINITY's Avatar
unplug the tps and see how it drives
Old Jul 11, 2012 | 08:12 AM
I checked the timing useing the jumper wire in t1 to e1 port and set it to 10 degrees. Motor running at 800 rpm. I did ohm the air flow meter and it was within spec
Old Jul 11, 2012 | 08:34 AM
TNRabbit's Avatar
This is one symptom of a bad or mis-adjusted TPS.
It could also be an issue with the distributor or VAFM as well.
Start with the cheap things first. Spec the TPS & try readjusting it.
Have you checked for CEL codes?
Old Jul 11, 2012 | 09:09 AM
4runnedup's Avatar
X2 on the afm and double check the vacuum
Old Jul 11, 2012 | 09:49 AM
Yep, check the TPS and adjust or replace if necessary.
Check the intake duct for any cracks in the bellows, pcv hoses, etc., and that the door in the VAFM moves smoothly.
Old Jul 11, 2012 | 01:11 PM
I'll have to download how to check the tps. I have vacuum and all the intake boots look good. I do have another tsp and distributor off an earlier model but ill have to see if I can use them in mine and how to set the tps
Old Jul 13, 2012 | 02:13 PM
I also failed to mention that the motor kind of stumbles at idle. Just like a little miss. Can also feel it at 40-45 mph. At steady throttle
Old Jul 26, 2013 | 11:34 PM
ghostgxz's Avatar
Did you ever figure out the problem? My dads 4runner has the exact same problem, minus the miss at idle
Old Jul 28, 2013 | 07:09 PM
mr8a's Avatar
Keep me posted, same problem. Also put new thermostat and still running too cold, cant ˟˟˟˟ to od
Old Jul 30, 2013 | 03:35 PM
ghostgxz's Avatar
Look at my last post #21
https://www.yotatech.com/forums/f116...13/index2.html
Old Aug 2, 2013 | 05:03 PM
ghostgxz's Avatar
Ok more importantly see my next post after that
https://www.yotatech.com/forums/f116...l#post52103138
delmert
Sep 30, 2015 04:34 PM
Poppie51
Aug 15, 2015 11:02 AM
agrout
Aug 13, 2015 06:12 PM
Sidherish
Aug 2, 2015 01:42 PM
