highsteer /steering box angle
Old Jun 25, 2012 | 01:23 PM
runs-on-4's Avatar
mocked up my steering box. how does this angle look? not really sure how its suppose to be
Old Jun 25, 2012 | 02:05 PM
dropzone's Avatar
Fossilized
Angle looks pretty good but I wonder if the box needs to go a little further forward. The distance between the two rods looks a little close than necessary. I would be worried about them binding
Old Jun 25, 2012 | 02:09 PM
drew303's Avatar
Looks good to me. The arms are fine...the tie rod moves back as the axle moves up. My drag link over hangs the lower and they clear each other fine.
Old Jun 25, 2012 | 02:13 PM
runs-on-4's Avatar
at full left turn the right side tie rod almost hits the leaf. but its fine on the other side. any suggests
Old Jun 25, 2012 | 02:14 PM
drew303's Avatar
Those tie rod ends look weird to me? Doesn't look like the drag link is hooked up? Also is your tie rod in the outter hole? hard to see...
Old Jun 25, 2012 | 02:19 PM
runs-on-4's Avatar
everything is hooked up not bolted down very tight, what do you mean by outter hole?
Old Jun 25, 2012 | 02:20 PM
waskillywabbit's Avatar
Cut that old bracket off that looks like ass
Box could go a tad more forward but should be fine.
:wabbit2:
Old Jun 25, 2012 | 02:23 PM
runs-on-4's Avatar
:wabbit2:
ya i know it looks bad. gonna take it all apart next weekend and clean it up real nice like. in a little bit of a time crunch to worry about looks im going for function first
Old Jun 25, 2012 | 04:49 PM
bryy's Avatar
hey so im doing this too and have a couple questions.
how much did you remove out of the engine bay to get in the and be able to work the power steering box without interference.
also what year is your truck? since I noticed you mounted your front hanger one inch forward
and How did you get the round u bolt on the drivers side inside with the truss there. I could only fit square ones on the inside perches and round ones on the outside perches.?
thanks
Old Jun 25, 2012 | 07:26 PM
drew303's Avatar
looks like one rod isn't connected.. can't tell which is bolted on the arm.
Old Jun 25, 2012 | 08:09 PM
scuba's Avatar
Almost looks like he is using a type of y-steer setup where the tie rod end on the drag link is stuck through the tie rod.
Old Jun 25, 2012 | 09:11 PM
drew303's Avatar
good catch i see it now. It's bolted thru the drag link.
Old Jun 30, 2012 | 02:33 PM
runs-on-4's Avatar
word to the wise. dont buy highsteer like this. had to go buy trail gears kit today
Old Jul 1, 2012 | 06:14 AM
What kind of "high steer" kit was it? Or was it one your bought off someone who had booty fabbed it?
:wabbit2:
Old Jul 1, 2012 | 08:52 AM
runs-on-4's Avatar
it was an unknown brand..i took it to a buddys house and he said it had gm 1ton tierods.
bootyfabbed it was. it was a good deal so i took the risk.
Old Jul 1, 2012 | 08:57 AM
bone collector's Avatar
so why didnt it work??
Old Jul 1, 2012 | 09:10 AM
runs-on-4's Avatar
not sure the truck shook if i hit a bump around 20-30. put the new highsteer in and its all good now
Badlander
Oct 10, 2015 08:05 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Scotttekoch
Sep 28, 2015 10:30 PM
ErikZ1220
Sep 10, 2015 04:53 AM
an1mal_69
Sep 8, 2015 09:40 AM
