Rear diff/Drive shaft (Pic & Vid)
Old Jul 7, 2012 | 03:52 PM
Badger62811's Avatar
So I crawled under my truck to grease her up and I found this.
Is there supposed to be this much play?
And I'm assuming a seal has given up...
http://www.youtube.com/watch?v=_FxDO...ature=youtu.be
Old Jul 7, 2012 | 04:03 PM
badattitude's Avatar
Universal joint is no good but the little play in the pinion shaft is ok. Looks like you need a new uni joint and a pinion seal.
Old Jul 7, 2012 | 04:25 PM
Well crap. Anyone have a good write up (with pics) about replacing U joints?
Old Jul 7, 2012 | 06:58 PM
TNRabbit's Avatar
It's all in the FSM. Should be a standard part of your Yota tool box~
Old Jul 7, 2012 | 10:25 PM
abecedarian's Avatar
Well, maybe not all tool boxes, unless you're speaking of the FSM being in the box.
Some of the u-joints are pressed in to the yokes, some are circlip.
The OP's look like the pressed ones. A shop should charge like 15-25 to press them in/out.
As for the fluid leak, the seal is gone. With the worn u-joint, I'd guess the pinion bearings have taken a beating too... though hopefully it's just the preload on the bearings has relaxed a little bit and let the shaft slap the seal into leak mode.
Old Jul 8, 2012 | 08:21 AM
Alright well I'll have to find time to tear it apart.. And I gotta find a place that'll do that ^^
A2theK
Jan 10, 2016 10:18 AM
jerusry
Oct 19, 2015 05:28 PM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
toyoda8488
Jul 5, 2015 10:18 PM
