PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 95 4Runner performance issue
  2. Spark...Fuel... But not cranking...
  3. Aftermarket 3.0 heads
  4. 1989 PU V6 Throttle Body Replacement
  5. 1988 Toyota 4runner brakes
  6. Can't throttle after cold air intake
  7. Power door swap, in need of help asap.
  8. 16" Wheel Tire Size 90' Pickup 4WD
  9. better milage
  10. 3.0 water pump known issues??
  11. 3VZE block surface condition (from blown head gasket)
  12. Timing Belt
  13. The little Yoda that could...
  14. super tech moyer oil?
  15. Brake Bleeding
  16. Pulling a 22re with trans, how high off the floor? Any input?
  17. Help?!?
  18. Location of Hi/Lo Ports for AC 89 4runner V6
  19. truck wont crank when hot
  20. Upper Control Arm Bushings R&R: What's Best?
  21. 1990 2wd suspension trans and drive train upgrade
  22. Locking gas door for '84-88 pickups
  23. Mass Air flow sensor
  24. Difference with T100
  25. fuel issues
  26. looking for any good pics/diagrams on cable hook up for temp slider
  27. Water leaking from exhaust manifold??
  28. 1988 4Runner gas tank restoration sage
  29. Worrisome noise.
  30. Warning Turn Signal Flasher Location?
  31. 3vz code 25 engine lean
  32. Ac hoses and breather locations?
  33. Front diff noise?
  34. 1st >> 2nd Gen Frame Swap
  35. Rod Pins & Journals
  36. It Cleaned Up Nice, Even Better Than I Expected
  37. pinion seal leaking and loss of power at 50mph?
  38. Switch intake plenum between 91-92
  39. Knock/diesel rattle
  40. Wiper bushing part troubles.
  41. cold start good, wont start after driving
  42. 86 1 Ton pickup won't start
  43. need help identifying instrument cluster (89 pickup w/3vze)
  44. A/C Port question
  45. Lift Kit Question
  46. 22RE VS V6 differentials
  47. Heat Shield Location?
  48. 1992 22re pickup Alternator failure
  49. 95 4Runner 3.0 V6 Fuel Pump
  50. Help. 4x4 seems to engage but no work.
  51. Machine Work Cost
  52. ifs lifts
  53. Slight buck after sitting..
  54. Replacing rear differential bearings
  55. But that price?!?!?!
  56. Clutch Choices. Which one?
  57. 1991 4Runner No Spark
  58. Alternator Bolt Issue
  59. 1986 stock bumper lights?
  60. First 500 miles oil type
  61. Can anyone give me details on turbo charging a 3vze? I need help with fuel and timing
  62. 87 22r no power
  63. I have a idling and drivability issue! Please help!!
  64. Caster/camber alignment
  65. No power
  66. Fuel injector replacement now won't start
  67. Occcasionaly,no crank or start
  68. Rear end still sagging, even after new leaf springs?
  69. 2nd gen 4Runner bumpers
  70. bolt size oil pan?
  71. 4runner 2 piece dash vs 1 piece
  72. Bolt behind the rear brake shoes
  73. Missing Bucking Jerking Stuttering Misfiring 3.0
  74. My Truck is Dead and I had to Walk Home - HELP!
  75. Identify this wiring plug
  76. HUB Centric vs LUG centric - kvetch with respect to "Chevy: wheels
  77. 87 vs 83 22r Igniter compatibility question
  78. What is this part called?
  79. Need advice- HG blew on 255,868mi engine... Rebuild/replace, or sell?
  80. 90 toyota pick up 2.4 rwd starts but shuts off in about 10 seconds
  81. What is this part? 86 Aisin Carb
  82. starting issues
  83. Toyota output seal
  84. ecu mount
  85. Need help draining/adding AC compressor oil to a 92 22re
  86. Another Downey Torsion Bar Question
  87. 1990 3 Liter A/C Question
  88. Condenser fan
  89. Quick Question: Shifter Seat...
  90. Possible to Rebuild 2pc Rear Driveshaft Cardan Joint?
  91. 92 22re wont stay running ?
  92. No fuel no spark HELP!!!!! 3.0
  93. Missing Bold on Coolant Pipe
  94. Power steering pump questions?????
  95. Throttle body.
  96. Bj spacers
  97. Question on charcoal cans?
  98. Bearing Puller Tool
  99. 22R What is this gasket called and where can I get one?
  100. Vacuum hose pictures?
  101. Head swap 22re 1987
  102. In need of hard core EFI & ECM techies!
  103. Long bed swap
  104. New (to me) 89 4runner
  105. Truck will start only if I put starter fluid in them die 92 toyota pick up 3.0
  106. When to use head shims?
  107. 22RE runs great cold,, rough, CEL and surges when warm
  108. 89 Flatbed Longer driveshaft, beefier springs & heavier Axle?
  109. Just in neutral okay if towing 10-15 miles 4 flat with 5 speed?
  110. LSPV Removal
  111. 3.0 headers
  112. Part compatibility for 1st and 2nd gen 4runner REAR WINDOW REGULATOR
  113. 3vze #1 water bypass pipe
  114. tailgate switch
  115. Intake manifold and plenum
  116. Hello. I run a Toyota Hilux 2.4 TD 1999 Mk4. Recently I just get a click on ignition.
  117. Help with low end bog/hesitation 22RE
  118. Is my 85 and 87 computers interchangeable?
  119. my 95 4runner wont start :(
  120. parts to replace with new 3vze
  121. Slamming door on 4Runner triggers unknown relay
  122. Is my transmission toast?
  123. Weatherstripping on cab above door?
  124. Name this 22RE gasket
  125. 3vze Rebuild Pump Prime
  126. Little Red Machine is sick.
  127. Should I replace this idler pulley?
  128. 3vze year need help!
  129. What is this thing beneath my intake?
  130. 22R Noise Video
  131. 1987 22rtec california smog pass and stuff.
  132. motor oil ?
  133. difference between 2.4l & 2.4lt injection pump
  134. Water in rocker panel
  135. Leaky axle seal
  136. Loose diff breather cap
  137. 3rd gen pickup & '93 4Runner parts compatibility
  138. 1988 Toyota pickup CODE 51 and 52
  139. 88 22re one click no crank
  140. My '91 4x4 22RE rebuild
  141. Suspension Question
  142. yet another power window problem....89 4runner
  143. Engine swap... Three bolts remain to complete!
  144. Transmission type
  145. squeaky clutch pedal 92 pickup
  146. Vacuum Leak
  147. battery isolator
  148. 1984 4runner AC Compressor wire plug in
  149. 1984 4runner AC Compressor wire plug in
  150. 3vze Rebuild. Finally made a decision
  151. Will an '84-'85 front brake cable fit an '88 truck?
  152. 4Runner Windshield Wiper Question
  153. Body lift bushings
  154. Rough idle and noise after engine work
  155. cannot open hood 4 runner
  156. Magnetic transmission drain plug
  157. Rear driveshaft came apart, how to align when putting back together?
  158. Need help before I buy this 3vze!
  159. 94 Toyota Pickup Xtra Cab 4x4 3.0
  160. Looking For Alternatives to The 3VZE Exhaust Crossover Pipe
  161. 3vze issues
  162. problem with 91 toyota sr5 4x4 pickup
  163. 1995 pickup 4x4 3.0l v6 automatic - coolant leak behind water pump pulley -
  164. Anybody Have Experience Welding On A 3VZE Exhaust Manifold?
  165. 1990 4Runner
  166. Adding A/C to '92 pickup 3vze
  167. Cruise Control Flashing 5 times 1990 4Runner
  168. Shifting problem
  169. 3.0 Exhaust manifold gasket replacement
  170. 89 3.0 VZE 4Runner lacking power
  171. Fuel Injector Connectors
  172. Front end, Driver side clunking - 88 Pickup 4x4
  173. 22RE head / rocker assembly identification?
  174. 91 pickup clutch problem
  175. Rough Idle
  176. 3VZE Valve Cover Sleeve Insert Missing
  177. Truck running rich
  178. my 92 toyota pickup 22re only has 86k miles on it. the check engine light came on.
  179. Need Advice
  180. 1990 22wd 22re starter ?
  181. Question about throttle body and breather tube
  182. The Toyota Vehicle Security System - Factory Alarm ("Dealer/Port Installed")
  183. Rebuild or Replace
  184. Valve Adjustment
  185. 4lo won't stay locked in position??
  186. Transmission overheating when climbing on the trails!?
  187. Best place for fuel pump/sending unit kit?
  188. 1990 4Runner rear wiper wont work... Im stumped! HELP!
  189. CE at highway speeds
  190. No CEL, No Start
  191. 89 Pickup sputtering on acceleration after fixing exhaust leak (IM STUMPED)
  192. 3VZE Hose Classification
  193. 87 PU SC Passenger Side Sub Woofer Box Fix
  194. Shock replacement help
  195. 1989 toyota 4runner
  196. Engine temp running hot
  197. Crankshaft, camshaft, and rotor not all aligning up at TDC
  198. Any idea with this wire is for?
  199. 93 3VZE timing belt replacement
  200. Engine paint kit?
  201. Where can I get a solid rear window for my truck?
  202. old guy-old pickup- old problem
  203. 22re rough running
  204. 93 3.0 lost power
  205. thinking of buying this 1st gen 4runner V6
  206. 1990 Toyota Pickup Circuit Open Relay Location
  207. 20R water pump/pulley
  208. Head Gaskets
  209. 22re rough running
  210. '87 SR5 Digital Dash Flashes
  211. 22re knock
  212. Drifting on highway plus loose steering
  213. '87 Dually BurningMan Artcar runs ruff after it heats up
  214. FJ60 grill clips removal?
  215. Coolant Leak Help
  216. WTB Campershell for 1994 4x4 xtra cab
  217. Head question
  218. Rear end sagging
  219. info
  220. 95 pickup oil light
  221. My Ride
  222. Speedometer help please
  223. 3.0 vz-e
  224. Loud humming/whirring sound from front end after 4WD on pavement
  225. Missing on 1 & 2
  226. Vapor lock of failing fuel pump?
  227. Squeaking on 4 wheel
  228. '92 4rnr interior panel removal/sunroof drain cleaning
  229. w56 assembly ???
  230. Broken timing tensioner bolt in head
  231. 1994 Toyota Extended Cab Lifted Pickup Value ?
  232. 86 22r 4X4 Weber 32/36 DGEV Fuel Shut Off Valve
  233. brake
  234. I've a front end noise
  235. 3VZ-E Leak Identification Help
  236. Windshield compatability between pickup generations
  237. Newer rear bumper on 84-88 pickup?
  238. Intermittent rough run issue
  239. What donor to look for to make this swap have as little hurdles as possible
  240. 2nd Gen '95 Limited Vs. Other Styles
  241. New cylinder heads
  242. 3VZE Head Gasket Project Questions
  243. 94 Pickup 22RE. Trying to find a horn.
  244. Looking for a good shell
  245. Looking for an 86' FSM???
  246. Blower motor not working on my1994 Toyota T100
  247. Air Conditoning problem
  248. 1993 4Runner 3.0L No crank, No start
  249. Air Conditioning
  250. 94runner rear lift
