- HELP! 87 22re Wont Start HELP!
- Tire Pressure Question
- 32x10.5 R15 on my '91 Runner?
- Raise my 4runner a little bit higher...
- My new '92 Pickup
- Rusty water in the air filter????
- replacement sheet metal for 1990 x cab bed
- i found this at the junkyard
- 85 4cyl. 4runner third in 88 v6 rear?
- Pressure washed engine now charge light is on and alternator doesn't work
- electrical problem with my 88. one after the other...
- I love roll bars (56k death)
- how much should i pay for the new head gasket job
- 22RE misfiring
- Still no compression in #4cyl on 94' pickup
- gotta love your kids...
- i need a little help with my grounds
- Updated + Sunday Project =)
- 3vze torque specs
- 1988 pick up 22RE above 4000 feet
- 33x9.5 on 7.5 Rims?
- 3rd member swap question
- stock 22re egr bolt size?
- tow 91 mr2 turbo with 91 4wd pickup
- Pickup Diesel or 4.3?
- 86 Auto - Man Swap
- need HELP!!
- Cheap way to lift rear end!
- Anybody used the Big O, Big Foot X/T tires?
- new truck small problems. wanna help?
- Mounted the LightForce lights
- "Clacking"
- Stuck Brake Drums, Could use some help!
- 87 - 22r fuel pump spacer
- Home made long travel?
- replacing t-stat
- Synthetic Oil what weight?
- tranny help?
- pin bushings
- Anyway to unsieze a caliper piston?
- W-56 transmission compatibility
- Replacing Front diff gears
- replacing windshield?
- 88 trans swap/wiring issues-no power on "start"
- 1989 4Runner body on an 83 frame...
- odd sight today on the highway
- fuel problems
- diesel pickup
- temp. gauge needle drops when fan is turned on?
- Can you replace the camshaft key on a '98 4cyl 4Runner?
- Some pitting on 22re head...Should it be resuraced
- 5.29's Installed!
- Removing leaf spring bushings
- Timing chain?
- I Replaced My Coil, Have A Question.
- 2nd Gen 4Runner Paint Scheme .PSD
- Axle rubbing on Gas Tank!!
- 90 4runner speedometer
- Transmission Too Hot?
- Best Exhaust system?
- Long travel help!!
- Rear Coil Spring Removal/Install 94 SR5
- 87 - 22r High Idle, Timing off, need Help!!
- afm sensor, have you tried it?
- 1st gen 4runner rear disc brake install
- 94'toyota pickup! no compression #4 cyl
- 93 4runner 3.0 leaking coolant
- blew another ifs diff
- 3VZ-E Injector problems
- coolant and thermostat issue
- chop up the 4runner? or not?
- cel code help
- turns over but won't start
- Head or manifold gasket.
- 3vze Distributorless Conversion
- Problems later with adding a lift?
- 210k Time for a new Japanese motor and tranny!
- '87 and '92 have same springs?
- Who's running 37's?
- pics of Taurus fan install
- Welded front. Aussie rear
- Just bought a 94 and need to get AC working
- best choice for hd alternator wire terminals
- windshield trim removal on 86 4wd
- What weight oil for the rear end and how much?
- Fuel Pressure Regulator?
- losing idle when hot
- Main fusible popping
- truck will not start after steering column work
- Heat-Pipe off Manifold Shield thingy
- Replacement Of Head With Pictures
- Steering Clunk/ Click
- sudden temperature drop
- Power steering pump question
- problem with engine 22RE,shaking..vibes
- 4runner got broken into need advice
- Locked my keys inside 1990 4runner. NEED HELP
- How to get to wheel bearing?
- coolant line busted and my 4Runner overheated
- Need walkthrough for valve tests 3vze
- Rear Pinion Seal Replacement
- Bad TPS, runs rough?
- 1st gen anti-theft???
- 95 4runner frame swap with 1990
- 1990 V6 Idles low and is sluggish
- Rear seats
- Engine acting Wierd
- Fitting 33x12.50 Swampers with BJ Spacers,Drop Shackle, and Diff Drop
- vibration while braking......
- New member needs opinion on newly purchased truck.
- Timing belt companion flange tool
- Cracked 22RTEC Block?!?!?
- DTC Decoding help please...
- 22ret CT26
- Need help regarding "Hesitation or stumble during acceleration"
- Paint job
- stupid ebrake light
- timing assembly
- 1992 rear window new motor gear stuck
- Newbie messed up throttle body
- will a leaking seal cause lower oil pressure?
- Rattle or clanking in driveshaft
- 22R to 22RE in an 84 progress
- How do I find the diameter of my clutch disk????
- 89 long bed DLX reg. cab
- Destroyed pinion / ring gear - questions
- Is there an Idle Increase solinoid?
- Thanks Corey for all of your parts :)
- removing wrist pins..?
- Need an exhaust system
- Need Help! Missfiring at 2k+ rpm's (Noob)
- Emissions Removal (offroad purposes) ; )
- passing emissions (yes, another one)
- I've got no 3rd or 4th gear
- Cleaning pistons...ideas?
- dash swap/hybrid dash
- Pulley Bolt Problem-CAN'T PUT IT BACK ON!
- Where is my Temperature Gauge Sending Unit?!?
- 2nd gen 4runner factory rear bumper mounting location
- 4runner replacment cargo carpet
- leaky power steering
- Need help with 22re
- Rusty battery tray
- heavier flywheels
- Seat Cover Reviews for 1st Gen??
- 3VZE Valve Troubles?
- Replacing Brake Fluid
- 87 22-RE Strange Starting Issue
- post-wreck front end rebuild with lots of pictures
- Pickup fuel tank upgrade
- Check it out Toyota part identification website
- leaking hydraulic clutch cylinder
- Dead Yota, now what?
- smoke comin off cat
- Pictures of 86 4x4 with 2wd box?
- oil pressure guage/sending unit ?'s
- 4.56 rear 4.88 front?
- 2nd gen 4runner bull bars?
- is there a better way to get the 22R engines to actually warm up faster?
- Keeping it clean? - 22RE rod bearings...
- 5.29 gear questions
- Suggestions for unblocking the engine coolant drain
- Bigger A/C Condensors?
- Intake studs Question
- Auto t-case question (3 pics)
- Burning Oil
- Hydrolocked my engine
- My Toy
- Can you identify this sound?
- Tps hell
- cheap paint job for '87 4runner?
- Really newb question
- Antenna mast for a 93?
- 1990 4 Runner 3vz-e Squeaking
- i have fuel spark and compression and it still wont start
- Help my wipers wont work neither will my back glass!
- Tps codes
- Bought a 92 'Yota pickup to replace my 4runner, but having probs...
- Chain slipping in t-case?
- 22re problem
- all weather floor mats
- code 21 funny problem
- Picked up a ticking, guzzling, no EGRing truck
- 92 ext cab 2wd to 4wd
- How many miles are on your ride?
- Ac Compressor
- 1st Gen 4Runner 3-gang Switch Panel Install - Lots of Pics
- KC Long Range. Damn Expensive!
- 86 22re question
- Will P265/70 R16 Fit 1988 Gen 1 4runner ?
- Upgrading Brake Calipers
- 1988 4Runner Auto Trans Issue... Kind of Wierd...
- 4Runner starts but stops immediately
- AAL's
- body work advise needed
- 4Runner miss
- Tranny problem
- Cabureted V. EFI 22R's
- weird jerking when taking off
- Ugly Stripes GONE!
- Cylinder Honer!!! HELP
- Need to find better halve shafts/cv's...
- 86 22re problem
- Need pictures of 3.0
- still having starting issures!!!
- Noisy valves on high miler...any tips/tricks?
- My truck was stolen but I got it back and need some help
- Overheated Engine -Now it won't run
- Hesitation at take off
- Anyone used the Daikin clutch kit?
- new thermostat and now ??
- I'm now part of the 1st gen 4Runner owners club!
- timing chain with no marks or bright links
- EGR Gurus
- Door Panels
- 86 pick head liner remove
- manual steering swap
- 91 3vze 4wd 3 in lift manuel
- regearing or not?
- Hard Vibration in Hood, Steering Wheel, and Floorboard
- fuel line diagram?
- New guy, timing chain ?
- Bushings for Surf/4Runner
- Trouble putting my 3.0 back together
- product of bed swap.
- Check Engine Light, but no DTC Codes
- Timing chain and clutch, what else should I do when I am in there?
- Truck finally died...
- Downey 3.0 Headers/Exhaust System
- head gasket?
- Frame spec
- Parking light / Signal light mod?
- head gasket replacement
- Quick Topper question
- Transmission Fluid Change on 1993 3vze 4wd
- Alarm Install question
- LONG Cranking, Hard Start, Cant Find answer
- 95 4runner 3vze help
- Sold the '93 Pickup
- no power!
- Alignment
- 3vz problems part 2
- Noisy dash
- engine feels like it's missing some horsepower
- Finally decided on a soft top
- wet EGR modulator filter
- New Front Bumper on - Courtesy of Addicted Offroad
- Trailer hitches and spare tires!
- VIN Number Help
- "whoring the truck"
