Pickup fuel tank upgrade
Old 09-09-2009, 08:08 AM
mxridercrf450r's Avatar
Do any of your guys know if a larger tank from another Toyota model (4runner, 4x4, Tacoma), will fit nicely between the frame rails on a 2wd pickup where the spare tire is?
Old 09-09-2009, 08:12 AM
4Crawler's Avatar
One option that may work:
http://www.4x4wire.com/toyota/tech/gas_tank/
Have heard of folks using a tank from some other vehicle back there, or try this:
- http://nwmp.com/search.asp
Old 01-21-2010, 09:33 AM
I found this 19gal/72l gallon tank, but i cannot pinpoint which year and model pickup it was intended for. I would like to find a used one so that i can get all the correct internals. The supplier specifies Vin# RN106, which i think could be a Australian 4 door Hilux. Any input would be appreciated.
http://www.autopartswarehouse.com/sk...ts+%26+Mirrors
Old 01-21-2010, 10:46 AM
paynemw's Avatar
i want to know how you intend to fill it... i was pondering the idea of adding a fuel tank where my spare was on my 2000 T4R but how to fill and the specifics were hard to comprehend
Old 01-21-2010, 01:09 PM
I wont have a bed, so routing the filler wont be a problem. You could cut a 2.5"-3" hole and route the filler neck through the floor, or mount the neck to a rear fender using an aftermarket door
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Pickup fuel tank upgrade
