Bigger A/C Condensors?
Old Sep 8, 2009 | 06:13 PM
jdw1's Avatar
does anybody know a company that make bigger condensors for 87 pu to aid in better cooling of the refrigerant?
Old Sep 8, 2009 | 06:23 PM
myyota's Avatar
You might try one off of a later model 4Runner or something like that, 4Runners have a larger interior compared to a truck, so the condensor should be bigger, but i don`t know if you could make it work on an older truck though, but it would be worth a try.
Old Sep 8, 2009 | 08:51 PM
jdw1's Avatar
thanks. i'll look into it.
Old Sep 8, 2009 | 08:57 PM
ozziesironmanoffroad's Avatar
you know, this might be a tad more than u want to do, but why not take the a/c system out of a tacoma (they blow pretty darn cold!) and mcguyver it into yours? when i do my a/c system in my truck i plan on using a condensor and blower from a newer 4runner then rigging it up to mine. (our blowers are WEAK!)
Old Sep 9, 2009 | 12:22 AM
DeathCougar's Avatar
The A/C systems blow plenty cold when they are functioning properly.
Try fixing yours first. A larger condensor isn't going to help you
Old Sep 9, 2009 | 06:40 AM
Marc's Avatar
x2 - they ran these trucks in some pretty hot countries
Old Sep 9, 2009 | 06:56 AM
TNRabbit's Avatar
If it's not cooling to your expectations, my guess is there's blockage/damage to your condenser coil....
Old Sep 9, 2009 | 08:21 AM
or....perhaps... your low on freon
Old Sep 9, 2009 | 05:26 PM
turborich's Avatar
Like the others have said, You may have some other issues. I would try to clean your condenser with a garden hose & check for proper charge. You may also want to check your fan clutch as well. Do you have the fan shroud in place? On a 110 degree day as long as I'm moving my A/C will blow every bit of 40 degrees from the center vent.
Old Sep 9, 2009 | 05:55 PM
abecedarian's Avatar
some 4Runners had a 'super-cool' option for the condenser, which was a 6 row (or something like that) set of coils in front of the regular condenser. Hoses are a little different so that may be an issue.
That setup would be the ticket to ice in the cab of a pickup, even if you're using HFC-134a.
Old Sep 9, 2009 | 06:04 PM
iamsuperbleeder's Avatar
1) I'd check the refrigerant level
2) Check to make sure the fins are clean
3) if both are good, then you may have an internal problem, like a blockage, or just a compressor going out
also, adding an electric fan that kicks on with the AC clutch really helped mine too, while sitting still
Old Sep 9, 2009 | 06:10 PM
... A larger condensor isn't going to help you
Hmm... I missed this completely. It doesn't matter much about the efficiency of the compressor or evaporator if the condenser coils can't remove heat to convert the refrigerant back to liquid.
In my house, and every other house, as well as every vehicle I've ever seen, the condenser coils always have more surface area than the evaporator coils: if the condenser can't radiate the heat, the evaporator can't cool.
Old Sep 9, 2009 | 06:16 PM
myyota's Avatar
Thanks Abe
You just answered a question that ive always wondered about, my 86 4Runner has that extra 6 row (or what ever) set of coils in front of the regular condensor and i could never figure out why, so now i know what there for.
Badlander
Oct 10, 2015 08:05 PM
Ktm526
Oct 7, 2015 05:14 AM
bryan34w
12
Sep 30, 2015 02:50 PM
Tacoma1313
Sep 8, 2015 01:27 PM
Dparr2ndgen
Sep 8, 2015 01:06 PM
