Problems later with adding a lift?
Old Sep 13, 2009 | 08:53 AM
littleblue4runner's Avatar
I have been lookin at a 2 inch lift kit from toytec and its a add a leafs in the back and a spacers in the front for $239. If I was to do it, will I have steering problems later down the road?
Old Sep 13, 2009 | 09:02 AM
waskillywabbit's Avatar
No.
Old Sep 13, 2009 | 09:03 AM
874runnersr5's Avatar
Spacers in the front as in ball joint spacers?
if so, youll need a alignment after you install em
Old Sep 13, 2009 | 09:09 AM
could i do it myself at my house? yes ball joint spacers.
Old Sep 13, 2009 | 09:13 AM
Install the 2" lift. Yes.
Alignment. Probably not.
Old Sep 13, 2009 | 09:17 AM
Jay351's Avatar
depending on what kind of add-a-leafs they use your leaf packs might get worn out.
Mine are turning into a M shape... after bout 2 years of running a poocomp short style add-a-leaf (including a few intense wheelin trips!)
Old Sep 13, 2009 | 09:21 AM
so get it? or would you get something different is you were doing it to your truck?
Old Sep 13, 2009 | 09:30 AM
really?
Old Sep 13, 2009 | 09:40 AM
what to ball joint spacers really do?
Old Sep 13, 2009 | 10:01 AM
Jay351's Avatar
THey are installed above the upper balljoints, they lower the spindle and lower control arm 1.5" (or however tall the spacer is).
This allows for added travel, clearance and ride comfort without really doing much.
for the rear I would put new springs in, but its not cheap.
A long style add-a-leaf would be okay.
Old Sep 14, 2009 | 03:03 PM
why does it not mess up the steering?
Old Sep 16, 2009 | 06:43 PM
abecedarian's Avatar
It does mess up steering. BJ spacers will push the lower arm down without affecting the upper arm, causing the lower arm to pull the lower BJ inwards, pulling your camber towards positive, and will also effect your caster and toe, as well as affecting how your camber, toe and caster all change as a wheel cycles from full extension to compression and back.
And for the 'kicker', BJ spacers will make your vehicle ride higher but will not keep the suspension from compressing any more than it did before... so if a 31" tire rubbed w/o the spacers, it might clear with them but a hard bump will make them rub as if the BJ spacer wasn't there.
Flying91
45
Apr 11, 2024 04:39 PM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
Yota.Jay
Jul 23, 2015 08:08 PM
timmJ
Jul 7, 2015 02:01 PM
