Tps codes
Old Sep 8, 2009 | 10:57 AM
ThePlumber's Avatar
Tps codes
94 PU 3.0.
Will a TPS log a code?
I have no codes stored.
But I do have a stutter under light throttle. (50mph in 5th gear)
I've also performed the "Driving Test"-E1 to TE2, made sure that it behaved the same, and again, have no codes stored.
Just wondering if the TPS will store a code on this system.
Thanks.
ThePlumber.
Old Sep 8, 2009 | 11:08 AM
4Crawler's Avatar
Yes, but typically on if there is a dead short or open in some of the TPS connections:
- http://www.off-road.com/toyota/tech/codes/index.html
You can test the TPS and see if there are any out of spec readings or dead spots if you do a sweep test:
- http://www.4crawler.com/4x4/CheapTri...#TPSAdjustment
some drunk guy
Aug 3, 2021 06:09 PM
Longbed 90
Mar 11, 2019 12:38 PM
Firefightersink15
Nov 23, 2015 10:32 PM
larrys93pickup
Sep 17, 2015 07:05 PM
moparbay
Sep 3, 2015 12:48 PM
