pics of Taurus fan install
Old Sep 12, 2009 | 09:49 PM
abalagtas's Avatar
Ok...I've read the posts on the install, but they don't have pics on how there are mounted. I have a hybrid FAL fan that disintegrated and took out the radiator in a frontend accident....by hybrid I mean the fan controls no longer worked (and were removed), so it was run off a temp sensor in the radiaor connected to a relay.
I'm hoping I can just swap fans...most of the writeups seem a little more complicated.
Does anyone have pics of how they installed their fans?
Old Sep 13, 2009 | 06:14 AM
waskillywabbit's Avatar
http://www.toyotaoffroad.com/Article...an_Install.htm
Old Sep 13, 2009 | 06:17 AM
iamsuperbleeder's Avatar
Originally Posted by waskillywabbit
why are there no finished install pics?
I think that would be more helpful than a pic of the donor car, lmao
Old Sep 13, 2009 | 06:19 AM
If you match that fan up to fit the shroud bolting it on is easy.
Old Sep 13, 2009 | 06:28 AM
I'd post pics of my 16" fan install, but my photobucket account bandwidth shot through the roof when I posted pics for selling my truck, so now none of the pics work untill the 16th of this month, lol
not a Taurus fan, and not a two speed, but hooked to a temp control box, and an AC over-ride on, and also a manual over-ride on and off installed with a 3 position switch in the cab, it works really well
Old Sep 13, 2009 | 06:32 AM
934rnr's Avatar
Here my old cardomain page link: http://www.cardomain.com/ride/423976/6
Check it out lots of pics hope it helps.
Old Sep 24, 2009 | 10:18 PM
abalagtas's Avatar
I finally got my fan....I was looking at your site and was wondering how you mounted the fan on the side that you trimmed?
Also, it says you took 1/2 in off the FRONT of the shroud...did you need to? I would like to keep using the mounting holes.
As far as wiring, do you know which pin is for the low speed?
Old Oct 14, 2009 | 03:43 AM
abalagtas's Avatar
I thought I would follow up and show pictures of my install:
The fan on the radiator
I cut and notched the long side of the fan to uses it for mounting.
notched end
sensory and eFan mounting tabs....I put them on the ribs of the fan.
I didn't have the connector so I made mine. I tested the leads the center one was only 10amps and the left side was 18 amps....so I'm using the lower amp setting.
close up of the other side
I'm using a hayden relay/sensor kit. I mounted it in the engine fuse box.
I will be wrapping the quick disconnect in a loom
Old Oct 14, 2009 | 05:35 AM
Marc's Avatar
Looks good. Way to go.
coryc85
Sep 9, 2015 06:24 AM
Scotto6591
Sep 1, 2015 03:24 PM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
1996Taco
Jul 20, 2015 12:02 AM
zd92655
Jul 5, 2015 04:25 PM
