Fuel Pressure Regulator?
Old Sep 12, 2009 | 05:37 PM
854x4's Avatar
I was working on a 22re and I forgot to hook up the return line to the fuel pressure regulator. I turned the key on to prime the system but I did not start the engine. When I turned the key off gas started spilling out of the return line hook up on the FPR. There was no vacuum applied and the engine was not started. Was that supposed to happen or is the fuel pressure regulator bad?
Old Sep 12, 2009 | 05:52 PM
abecedarian's Avatar
So the fuel pressure regulator keeps some pressure in the line in front of it, right?
And if the fuel pressure regulator sees there is too much pressure in the line, it does what with the extra fuel?
(hint: return fuel back to the tank)
Old Sep 12, 2009 | 06:00 PM
iamsuperbleeder's Avatar
lol, no you're fine, but that'll tech you to leave open fuel lines unhooked wont it
two things to never leave exposed; 1) open fuel lines, and 2) constant hot wires charged with 12v
ESPECIALLY if the two are close by one another
Old Sep 12, 2009 | 07:19 PM
854x4's Avatar
OK so its supposed to do that. I didnt think it sent fuel back to the tank unless it had vacuum applied to it. Thanks
jbv808
Aug 6, 2021 04:47 PM
Doug4320
Mar 24, 2018 10:11 PM
Poppie51
Jul 23, 2015 05:03 PM
v_man
Jul 23, 2015 04:01 PM
Poppie51
Jul 16, 2015 06:16 PM
