86 22re problem
Old Sep 7, 2009 | 12:17 PM
snowbordergreg's Avatar
86 22re problem
So i washed my truck (and engine bay probable causing my problem) and on my way back home I must have blew some sort of sensor i think. It still runs fine but is hard to drive. I have to shift at very low rpms and cant give it very much gas. I have no check engine light on. if i do give it to much throttle or drive to high of rpms it drives villently like cutting off and on the gas. Any ideas what I need to replace. I drive my 1986 4runner as a daily drive right now so suggestions would be helpfull. thank you
Old Sep 7, 2009 | 12:32 PM
hptechnician's Avatar
have you checked all your vacuum lines to make sure you didn't knock one off or loose?
Old Sep 7, 2009 | 02:14 PM
I didnt see anything that looked loose or came off but i guess i should check everything agian.
Old Sep 7, 2009 | 02:18 PM
vital22re's Avatar
totally a bro
sounds like either water in your distributer cap or water in the tps.
Old Sep 7, 2009 | 04:08 PM
How do I go about fixing this problem?
Old Sep 7, 2009 | 04:13 PM
unbolt the dist. cap. dry it out good with a rag, maybe leave it off for a day or so with the hood closed. There are probably better ways to do it, but that's where I'd start. As fro the drying the tps, I'll leave that to vital22re to give you advice. In other words, I'm not sure and would have to look at the part first
Old Sep 7, 2009 | 07:23 PM
It just seems like that if it was the distributer that it wouldnt start and run like normal before it drives. I could be wrong.
Old Sep 7, 2009 | 07:27 PM
BigBluePile's Avatar
Look over the tps, if it can't figure out where the butterfly is then it'll probably won't work so well.
Old Sep 10, 2009 | 04:18 PM
If the tps sensor was out wouldnt the check engine light be on? It might be time to just take it to a shop and have them figure it out.
Old Sep 10, 2009 | 04:26 PM
abecedarian's Avatar
check, clean and dry the connectors to the igniter / coil assembly and the air-flow meter.
Old Sep 10, 2009 | 04:32 PM
I think it would pop if the thing thing was just bad, maybe not for out of adjustment. Still would hurt to just check it. Or pay a butt load for some guy to tell you its doesn't run.
jbv808
Aug 6, 2021 04:47 PM
steve miller
Oct 10, 2015 01:40 AM
Odin
Jul 15, 2015 09:28 PM
Sandman
Jul 14, 2015 12:36 PM
ryerye13
Jul 14, 2015 08:27 AM
