How to get to wheel bearing?
Old Sep 12, 2009 | 10:14 AM
3000GTVR4's Avatar
I have a 1991 SR5 pickup, 3.0, 4x4, with ADD hubs. I need to inspect/repack/replace my passenger side front wheel bearing.
After doing some searching and reading up on here, I know a 54mm socket is needed and I have one of them as well as a new wheel seal. The only thing i am missing is an actually diagram, or step by step guide on how to get in there to the bearing. The old method of remember how you took it apart and put it back together the opposite way is possible I'm sure, but i would just like some reassurance.
So if anyone has a copy of the page in the manual, or a link to a how to that would be great!
Old Sep 12, 2009 | 10:57 AM
scuba's Avatar
RTFM newb
Old Sep 12, 2009 | 11:54 AM
peow130's Avatar
Well, he can't read the manual, without the manual.
http://www.ncttora.com/fsm/1993/index.html
Derrrrrp
Old Sep 12, 2009 | 12:34 PM
waskillywabbit's Avatar
Originally Posted by scuba
RTFM newb
WYM Scuba.
Old Sep 12, 2009 | 04:49 PM
Jay351's Avatar
Whats the point... just tell him what he wants to know instead of useless posts like that...
Make sure you got the 54mm socket, torque wrench and new inner oil seals for the rotor.
Old Sep 12, 2009 | 05:45 PM
Tofer's Avatar
Sponsor
RTFM newb
quit being a toolshed steve.....
Old Sep 12, 2009 | 05:46 PM
Lysmachia's Avatar
Here ya go.
Bookmark these babies along with the FSM link that was posted above!
http://www.4x4wire.com/toyota/tech/autohub/
http://www.4x4wire.com/toyota/mainte...t_end/bearing/
Make sure you pack those bearings with Moly grease well. Put a glob of grease in your hand. Thwap that new bearing into the grease (several times) till the grease begins to pucker out the other side between the race, bearings and cage. Rotate the bearing and thwack till you work your way all the way around and it it well packed with grease!
If you do the bearings, don't forget to replace the seals in there too!
http://www.4x4wire.com/toyota/mainte...nd/reassembly/
Lastly loctite and RTV are your friends when doing re-assembly!
Old Sep 13, 2009 | 12:43 AM
DeathCougar's Avatar
Derrrrrp
HEY! You stop having helpful logical posts RIGHT NOW PAL!
bigjstang
Jun 2, 2025 03:56 PM
glowz825
Jan 25, 2022 09:28 AM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
RBK
Aug 1, 2015 01:55 PM
PlayAwhile
Jul 20, 2015 11:36 AM
