problem with engine 22RE,shaking..vibes
Old Sep 12, 2009 | 11:18 AM
bodo4runner's Avatar
compression test
#1 - 142
#2 - 146
#3 - 145
#4 - 146
power is good!
engine mounts it's ok
I have new cap, rotor, wires, spark plugs, tailpipe, relatively new exhaust,PCV
no codes
timing is perfect, idle is set right, tps is right,fuel pump ok,fuel filter,air filter ok
thanks you, guys!
my videos:
http://www.youtube.com/watch?v=GnPu3...e=channel_page
http://www.youtube.com/watch?v=QPX7d...e=channel_page
Old Sep 12, 2009 | 11:25 AM
toyota4x4907's Avatar
That looks like as much vibration as all three (3) 22res I have owned. The exhaust shaking at the end of the first video could be from broken or damaged exhaust hangers.
Old Sep 12, 2009 | 11:28 AM
Kaydon's Avatar
Have you checked your PCV valve?
Old Sep 12, 2009 | 11:41 AM
1 year ago no shaking ,
http://www.youtube.com/watch?v=JrHxH...e=channel_page
but today
Old Sep 12, 2009 | 11:42 AM
pcv valve ok
Old Sep 12, 2009 | 11:51 AM
Kaydon's Avatar
o2 sensor?
those two things gave me a rough idle, but even with it tuned as good as it was gonna get - it still had a bit of a vibration. I just think that's the way it is.
Old Sep 12, 2009 | 12:05 PM
camo31_10.50's Avatar
could it be a vacuum leak????
my 22R idles like that..of course i've got a cam..so thats why mine shakes!
Old Sep 12, 2009 | 12:35 PM
iamsuperbleeder's Avatar
when's the last time you serviced the timing chain?
better yet, does the timing jump around a little at idler if you put a light on it?
if it does, pull the valve cover off and check those guides
I hear a little noise; could be from chain-slap
Old Sep 13, 2009 | 05:10 AM
timing jump ok, but timing chain i didn't serviced,
Old Sep 13, 2009 | 07:14 AM
Kaydon's Avatar
Get some starter fluid and check your vacuum hoses. All of them.
Old Sep 13, 2009 | 07:51 AM
spray whith WD-40 all vacuum hoses and nothing..
Old Sep 13, 2009 | 08:05 AM
Kaydon's Avatar
That's perplexing.
Clean your MAF for the hell of it?
Old Sep 13, 2009 | 08:57 AM
874runnersr5's Avatar
Mine somewhat does that to, i always though my mounts were going.. hmm im subscribing to this one
Old Sep 13, 2009 | 09:16 AM
Kiroshu's Avatar
Ok judging from everything you said you checked and is ok and right i'd have to say shes starving for fuel and or air. Your engine like alot of old engine is running nervously. This is usually caused from lack of fuel and or air. This is sometimes caused by vac leaks. Your sure your motor mounts are ok? Check fuel pressure. You sure your idle a timing are right? If you think so what are they? A stock 22re runs best at about 12 degrees BTDC and about 800+ idle. Any fuel leaks? Egr valve can also cause this prob. Does it have hesitation and or miss a beat upon drving ranges? There is also another thing, have you done the clutch in this truck? If so please tell me you didn't put a lightwieght flywheel on it.... because then thats why. Personally to be honest what your truck is doing is not really threating. Have you adjusted the valves? And make sure you do it hot.
Old Sep 8, 2010 | 08:31 PM
BajaRunner's Avatar
Did you ever figure this out?
I have the exact same problem. It seems like every few seconds I have a hiccup that causes the engine/truck to shake. Compression, timing and valves are good. Fuel delivery seems good, and I can't figure out whats going on.
The only thing left looks to be a sticking exhaust valve but my head was just redone about 4k ago.
Old Jan 1, 2012 | 08:22 PM
sinful's Avatar
I'm having the same problem.
any updates on this?
thanks
Old Feb 6, 2012 | 04:55 PM
"G"'s Avatar
"G"
Could be a clogged or dirty injector.
Old Feb 8, 2012 | 12:48 PM
sinful's Avatar
i sent the injectors for profesional cleaning, replaced fuel filter and double checked for vacum leaks. im still having the same issue.....engine shakes, exacly like the video above.
cant figure it out
Old Feb 8, 2012 | 12:49 PM
sinful's Avatar
im suspecting mechanical....a valve not seating/sealing properly?
Old Feb 9, 2012 | 09:57 AM
87Toy22r's Avatar
I have the same but a 87 toy 22r 2wd automatic (stock), my "hik-ups" at a stop then sputers to like 15mph than rides smoth!!!
