4Runner starts but stops immediately
Old Sep 7, 2009 | 06:51 PM
TSintercept's Avatar
So my 88 4Runner starts but stops immediately unless I hold down the throttle. Any help y'all can give would be great! Thanks
Old Sep 7, 2009 | 06:56 PM
toyota4x4907's Avatar
Any CEL?
Make sure the AFM is working correctly. Make sure the throttle plate is opening some and that the IAC valve is not clogged.
thadlinkwent's Avatar
Some more info would prolly get you more responses... like motor, trans, carb or f.I.
Old Sep 7, 2009 | 06:58 PM
oh sorry, it's the 3.0 V6
Old Sep 7, 2009 | 07:19 PM
lostINtheSAUCE's Avatar
i have a 1990 4runner that did the same thing. i looked at the intake and one of the hose clamps was loose letting in to much air so adjusted and tightened it and it fixed the problem. so you might want to check if its as simple as my problem was.
Old Sep 7, 2009 | 11:11 PM
9o7yota's Avatar
3.0 v6...EFI right? Not sure..it could be many things...Try an injector cleaner... Check your hoses like lostSauce said... chances are its something simple..but its definitely fuel related...
If its Carbeurated...haha..check your carb ports for clogs etc... do they even make carbs for the v6s? i donno...
Holding your throttle open: opens air valve and allows more gas to the injectors. Vacuum leaks could cause you to need to pin it..as well as clogged injectors or carb ports... maybe a bad fuel pump or filter bro... those are common probs to that too... as in not getting enough fuel pressure unless u really step on it..
Old Sep 7, 2009 | 11:13 PM
abecedarian's Avatar
No cracks in the tubing from the engine to the air filter?
Old Sep 8, 2009 | 05:31 AM
thook's Avatar
3.0's are EFI. 3VZ-E.......E = electronic
Troubleshooting guide........
http://personal.utulsa.edu/~nathan-b...sm/engine.html
Could be a number of things. Make sure everything's plugged in, too. I've had that happen to me more than once.
Old Sep 8, 2009 | 05:32 AM
thook's Avatar
Hi Kirk!
<<<<< Abe and Sin >>>>>
Old Sep 8, 2009 | 06:10 AM
Thanks guys, I'm sure it probably is something simple but I will try and found out today.
JF9243176
Oct 8, 2017 04:21 AM
bigblue82
10
Jul 6, 2015 08:27 AM
torgeir
Jun 25, 2015 05:26 AM
JF9243176
Jun 24, 2015 04:53 AM
JaredL
Jun 16, 2015 04:47 PM
