leaky power steering
welcome to the forums!
a 91 is not a T100. the T100's came about in late 95 (correct me if I'm wrong guys)
a 90 and 91 should be exactly the same
probably might even be the same between 2wd and 4wd, but I'm not 100% on that
I swapped an entire gearbox from a 90 4wd 4Runner on my 91 4wd PU if that tells you anything
mine is 2wd and has no abs, im not sure a bout the t100 though. what would be the difference in the line.i only need the steel part that runs under the radiator if that makes any difference.
Not entirely sure, but if you look at the bottom left of the second pic, you can see that all the lines end there and its not the pump or gear box, but the abs actuator.
http://www.toyodiy.com/parts/p_U_199...EA_4503.4.html
delmert
Sep 30, 2015 04:34 PM
