leaky power steering
Old Sep 9, 2009 | 02:58 PM
D.STARR's Avatar
Hey im new to the forum and i was jus wonderin if a 91 t100 power steerining return steel line would work on my 90 toyota pickup extra cab? thanks
Old Sep 9, 2009 | 03:01 PM
iamsuperbleeder's Avatar
welcome to the forums!
a 91 is not a T100. the T100's came about in late 95 (correct me if I'm wrong guys)
a 90 and 91 should be exactly the same
probably might even be the same between 2wd and 4wd, but I'm not 100% on that
I swapped an entire gearbox from a 90 4wd 4Runner on my 91 4wd PU if that tells you anything
Old Sep 9, 2009 | 03:17 PM
D.STARR's Avatar
so what ur saying is that it shuld fit??lol
Old Sep 9, 2009 | 03:21 PM
jason191918's Avatar
T100 came out in 93 (late 92). As far as the line goes, do both have/dont have abs? 2wd 4wd makes a difference too.
Old Sep 9, 2009 | 03:24 PM
ah okay, see I stand corrected then, lol
Old Sep 9, 2009 | 03:30 PM
D.STARR's Avatar
mine is 2wd and has no abs, im not sure a bout the t100 though. what would be the difference in the line.i only need the steel part that runs under the radiator if that makes any difference.
Old Sep 9, 2009 | 08:35 PM
on my truck (see sig) the lines run to/from the pump to the abs actuator then to the gear box. pretty sure 4wd makes a difference...oh..and so does the engine!
Old Sep 10, 2009 | 12:14 AM
drew303's Avatar
I've got no clue but I'm curious about why the power steering is in anyway connected to the braking system? I don't get it? That's bizarre
Old Sep 10, 2009 | 02:27 PM
Not entirely sure, but if you look at the bottom left of the second pic, you can see that all the lines end there and its not the pump or gear box, but the abs actuator.
http://www.toyodiy.com/parts/p_U_199...EA_4503.4.html
Zpd426
Jan 2, 2016 01:15 PM
delmert
Sep 30, 2015 04:34 PM
Up&Down
Aug 11, 2015 10:04 AM
toyoterferdayz
Diesel Swaps
Jul 27, 2015 05:25 PM
gmonnie123
Jul 26, 2015 02:44 PM
