- Horrible sound when hubs locked
- 23 Mpg!!
- Idle problems engine stalling
- 95 4runner transmission removal questions/help?
- disc brakes
- engine hesitation
- no brakes when started?
- 92 Toyota With Temp Problems
- brake problems
- 4WD issues
- What To Do??? Sell It Or Fix It!?!?
- Worn clutch?
- Pics Of Me And Friends From Diff.
- ABS Removal
- Manual Hub Cone Washers
- Did a drop down bracket! Axle still out.
- 89 3.0 cold stumble issue
- Coolant everywhere!!!
- 22re knocks at idle
- Bushwacker flare install question
- Newb help with a 89' Runner
- thrashed ifs diff mount
- stuttering on sharp turn - 95 4runner 4wd
- Airbags in rear springs
- Doorless
- what size blocks do i need?? newb question..
- Driving issues
- fuel filter
- What weight oil do you use?
- ARB question
- 86 Pickup differential bearings
- My Taurus Fan Installation.
- 86 4Runner Torque Specs
- Oil Gage
- longer shocks needed with 3" shackles???
- Head bolt debate??
- Tachometer and Odometer
- demelloe tacoma bed bar in a 94 p/u
- OK to 60/40 coolant ratio??
- installing coil spacers. need help fast
- Used stock skid - $30?
- Small Block Conversion
- Some random Newb questions/problems...
- Factory roof rack relocate?
- 1986 SR5 XTRA Cab turbo. What can I do to bring out some of the power?
- Overheating
- gears and mpg?
- CV boot and shocks install ?
- URGENT HELP! Ring and pinon bearings.
- grille
- 1990 4runner: new starter, doesn't start
- Super Shock Deal
- 3.4 Swap Options
- O2 sensor cable routing
- Rear Marker Light
- Some interesting taurus fan mod info. . . (to me at least)
- A340 shifting when cold
- removing windshield
- 86 auto o/d shift trouble
- 3.0 new engine runs rough
- All Pro rear bumper is going to fit, one way or another
- Water Pump
- 94 pickup overheating, 22re
- Selectable Lockers
- The debate in my head....rebuild vs. swap
- 1990 toyota pickup 4x4 ex cab 4X4 WONT ENGAGE
- Removal of Intrument Cluster
- 1986 pick up automatic shift indicator needed
- New drums & rotors... brakes still pulsating
- 93 4runner Crazy Rpm
- How do I replace this pulley bolt?
- Can it be Towed?
- check out this lift on a 90 pickup
- Pre Trip Tune Up- 92 4cyl
- Mean Green Alternator + 22RE
- what can cause coolant pressure build up?
- Squeal like a pig...
- 3VZE reborn one more time
- question re spindle bearing replacement part
- The Pre TB Ribbed Rubber Elbow Air Tube
- Ceramic Clutch
- Diagram/Picture of the Kick Panel Fuse Box?
- diff questions
- what part of the brakes is making the noise
- transmission about to blow
- '92 V6 runner w/ G254 rear diff locker available? Powertrax? Aussie?
- cel in wet weather
- need brake pads
- Spare Tire Removal
- 1988 tailgate stay
- Wheel bearing/seal?
- radiator repair?
- Looking for info on headers
- power steering knocking
- 2wd balljoint spacers
- Downey long travel kit?
- Crossover eliminator for 3.0.
- Transmission (mind of its own)
- simple Q re: ADD to manual hub swap
- ? about a/c
- Lockers and LSD combo?
- speedo cable replacement ?'s
- Rear end sag '88 4 Runner helper springs
- digital dash
- Problems with SMT6
- EGR Code 71
- Gear changes in 95 4Runner 3.0 Auto
- Question about speedometer and Valve Clearance check
- Oregon Engine Rebuilders, do they sell on Ebay?
- Running the con' with ifs?
- Busy Weekend
- Explain this code
- 4Runner sputter and dies COLD START
- Anyone Got A Spare Afm For 89 4cyl?!?!
- Valve Job parts
- brake drag....leading to bad mileage
- The failing alternator culprit...
- 1.5" wheel spacers install
- do you know what this part is?
- Need vacuum Hose verification for 94 runner
- Question on fan clutch
- 90 4runner sun roof
- Super Clean
- replacing fuel injectors and finding oil in the intake manifold...
- oil leaking from air cleaner
- Checking for Vacuum leaks/carb clearner
- Center Support Bearing
- Radiator hose help
- did isr pipe mod...runner stalling.
- 1978 Toyota Pickup Clutch Bleeding Problem
- Factory Sunroof Dimensions...
- 90 4Runner/22RE Bigger Exhaust?
- Rebuild 22RE or not?
- Break Booster Vacuum reading
- oxygen sensor?
- Tires locking.
- knock knock
- 3.0 to 3.4 conversion
- Question about FJ80 coils
- Newbie to Yotatech!
- 22re reman. head-quality shop to buy from?
- Tire Pressures in sand
- motor mount?
- replace rear diff or rear axle... in a bind
- 1991 4Runner Trans
- Soft-top plans?
- Paint Time
- timing chain broke-info?
- Can't find diagnostic connector.
- 3vze injector flow???
- 3rd gen rear diff. on a 2nd gen 4runner
- Will An 86 4 Runner Afm Work?
- timing chain
- Really Bad Leak
- Help! I've got an oil leak!
- [22RTE-Trucks] automatic transmission A340 H ?????
- Larger injector question.
- Need some info on cluster
- Embarrassing 3.0 Head installation issues...
- Homemade ISR mod
- Yakima Roof Racks>
- Need A New Radiator? $126 Shipped To My Door!
- 2'' Lift On a 2nd Gen 4Runner
- 3.0 PS Pump... rebuild or replace
- 87 4 runner v6 rad and fan
- '93 P/U needs new rear brake line....help?
- Tried the jumper and nothing..fuel pump
- FUEL INJECTORS (Help!)
- Maf Sensor, Good Or Bad?
- 3VZE runs rough & misses
- What should the TEMP be on a 3.0 ?
- Glowing Exhaust
- Need some help with 3.0L V6
- 84-88 4 runner - LN 130?
- Ignition Timing question
- 3.0 Oil leak musings...
- 22RE external head gasket leak? Pics inside
- Loud buzzing sound when accelerator is pressed down
- Cruise control not working...
- I need your input NOW, on my custom exhaust
- Serviceable EGR Valves?
- leaf spring bushings
- need fuel injector advice
- Manifold Pressure on 904runner
- 4runner headlights
- Are new headbolts REALLY necesarry?
- Another toyota turbo
- scratch on the crank
- Filling Tranny + T-case: From the top?
- radiator install question
- Cheap Muffler setup
- transfer case grind??
- 87 22re 4-runner will not start
- tailgate, will a 1989-95 fit my 1988?
- engine problems always happen at a bad time
- 190k
- steering box link, cant get it off?
- Fan bracket elimination.
- Getting at fan bracket.
- Tow Pkg?
- Fuel line? Fuel pump? Fuel injector?
- 94 v6 4wd when to change o2 sensors
- rubbing noise
- Warn Hubs $20!!
- Symptoms of bad flywheel
- 3.o auto problems
- Rear Differential
- Caliper hard line part# 90 4runner
- best place to get factory clutch ?
- Knock Sensor not hooked up
- Need quick help, idle adjustment!!!
- Overheating
- Help setup up 1st Gen 4runner Suspension
- Squeaky clutch pedal
- ? regarding 4Runner vs. Truck front bumpers
- head gasket repair
- altenator mounting bolt ???
- stock height/tire brand
- v-6 trannies
- Gear oil question
- Small leak... identify this part for me
- what's leaking
- 89 pickup radiator, is the 2wd the same as 4wd?
- Fuel Pump Help?
- Bilstein shocks for 1.5" lift. 10", 12" or 14"???
- Rpms
- Automatic "Drive Plate Cover" on a Standard?
- CEL codes and whats not the problem.
- Steering went out...
- need a 86 truck roll bar
- Tranny Removal ---> HELP!!!
- reputable machine shop in san diego
- 3vze ASS valve?
- advice on rear main seal and oil pan
- Spark plugs wires stuck???
- Hop..Hop...Hop....POP! -- Axle
- Rear Window not working
- NAPA clutch kits.......
- Replacing Front Rotors
- Fuel Filter Replacement, 1st Gen, 2.4L
- 90 4runner tailgate not opening...help.
- 90 3.0 rough idle, bouncing idle, rich condition
- shifter loose
- Power door lock
- 22RE Ideal
- Any knowledge on this reman?
- Engine dies when shifting...???
- Heres My Free 89 Yota And $200 Engine, Still Need Help
- Catalytic smeels on warm up
