OK to 60/40 coolant ratio??
Old Nov 17, 2006 | 10:32 AM
Toyo4x4's Avatar
Question OK to 60/40 coolant ratio??
Is it OK to use 60% coolant/40% distilled? I didn't buy enough of either .
Thinking if I used half the next jug of coolant to make 60/40, I could save it for the next change and do the same thing.
Old Nov 17, 2006 | 11:13 AM
eric-the-red's Avatar
It probably won't do any harm but water has a higher heat capacity than glycol. That means you'll get less heat transfer and cooling than you would with more water. Shouldn't be a big problem this time of year but it might be in the summer.
The freezing point will be lower with 60/40, but I don't thnk you have to worry about -40 or -50 in AZ.
Old Nov 17, 2006 | 02:41 PM
04 Rocko Taco's Avatar
[HIJACK]
Your avatar....Paintball mask???
[/HIJACK]
Old Nov 17, 2006 | 03:02 PM
Toyo4x4's Avatar
Yes it is! Now you can win the prize if you can name what brand it is .
I opened up the top vent instead of turning on the heat when draining the rad Oh well, at least 90% is fresh coolant.
Old Nov 18, 2006 | 06:01 PM
langzaiguy's Avatar
I've heard that you shouldn't go over 68% coolant.
Old Nov 18, 2006 | 07:12 PM
AH64ID's Avatar
You will have very very poor heat disipation capabilities. While coolant provides a higher boiling point and lower freezing point it holds the heat longer. The general rule of thub is 50/50, and if you live in an area that doesnt get too cold I would run 40coolant/60distilled... it will take less time for your coolant to cool, thou toyotas generally dont have issues cooling....
ladybugRC
458
Aug 21, 2020 10:41 AM
wberry85
May 17, 2016 05:45 PM
alexcarey
Oct 14, 2015 06:05 PM
kcaudill
Oct 10, 2015 02:39 PM
Odin
Sep 26, 2015 06:56 PM
