Getting at fan bracket.
Old Nov 6, 2006 | 07:02 PM
suprathepeg's Avatar
Can it be removed by itself or do you have to tear into things to get at it?
Old Nov 7, 2006 | 08:26 PM
mtnfreak's Avatar
Must remove: Upper radiator hoses, fan shroud, water outlet, accessory belts, #2 (big) timing belt cover, power steering support
Should remove (as long as you're in there & depending on when they were last replaced): # 1 & 2 timing belt idler pulley, water pump, timing belt, fan clutch bracket.
kawazx636
Oct 6, 2021 03:03 PM
JUICE222
Oct 13, 2015 08:50 AM
voiddweller
Oct 2, 2015 07:47 AM
voiddweller
Sep 28, 2015 11:21 PM
Matthew Perez
Sep 28, 2015 05:43 PM
