what's leaking
Old Nov 5, 2006 | 06:15 PM
traben27's Avatar
what's leaking
So i've had this leak that everyone told me at first was the rear main seal...but i'm thinking its not. Basically i've figured out the general area that its coming from and its from what ever is behind (as in closer to the cab) the oil filter. It's a cylinder object from what i can tell and it looks like the oil is leaking out of there somehow and running down onto the tranny.
long story short...what is that? any engine diagrams? thanks.
Old Nov 5, 2006 | 06:21 PM
mr toytech's Avatar
sounds like maybe the oil cooler. take the center bolt out and replace the two o rings inside of it. fairly simple if you know what your doin..
Old Nov 5, 2006 | 06:48 PM
rezrunner92's Avatar
Ditto. I would do it on the weekend and wash it out with paint thinner or carb cleaner or brake cleaner or... and let it sit for awhile. Do this a couple of times until the cleaner you use looks clean after washing the cooler in it. Then spray it as full of ether, (quick start fluid), as you can and shake it around etc. Then shake it out real good and or blow it out with compressed air and re-install. This will also give you a chance to inspect it real good for corrosion, cracks etc.
Don't forget to put a little oil on the "O" rings to ease installation. I plan on doing this soon myself.
Old Nov 6, 2006 | 04:13 AM
traben27's Avatar
thanks i'll probably do this later today if the rain stops. we're in the middle of a drought and of course it happens to rain the only day i need it dry.
he's gone
7
Dec 3, 2019 07:08 AM
4runnerjunk
Aug 22, 2015 09:06 AM
accuracy
Aug 4, 2015 08:05 PM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
