what part of the brakes is making the noise
Old Nov 14, 2006 | 07:02 PM
LegendofJake's Avatar
So my brakes recently have been going out,they seem almost spongy..When i press down on them at medium pressure they most of the time brake as theyre supposed to but sometimes they brake really hard suddenly.Also once my 4runner is coming to a stop or the last two seconds of braking it makes a click click click click click sound untill my wheels are completely stopped.
Old Nov 14, 2006 | 09:27 PM
bikeguy18974's Avatar
Not sure about all you problems but for me the click click click was the dust shield hitting the rotor up front. Bent it back and the noise went away.
For the rest of your problems, not quite sure, but if you did any recent brake work maybe the system needs to be bled better. Or if haven't done any work maybe you have moisture in the brake fluid and need to flush the system.
Old Nov 14, 2006 | 09:32 PM
91TPU's Avatar
clicking noise is usually the dust sheild, but sometimes the wear indicators when they have dug too far into the rotor, or have worn down far, they click cuz they dont always touch the rotor. if thats the case, you need to pads and rotors.
Old Nov 15, 2006 | 06:25 AM
MMA_Alex's Avatar
Pull a wheel and inspect. Check the dust shield, pads, and rotor condition. The sponginess is probably air in the line so they need to be bled for that issue.
Old Nov 15, 2006 | 07:27 PM
trythis's Avatar
Two possibilities:
Master cylinder is going, or much worse, and less likely, the vacuum boster is going bad.
voiddweller
19
May 2, 2016 09:10 PM
Dillon1983
Jul 7, 2015 06:47 PM
87blyota
Jul 1, 2015 05:26 PM
miceal383
Jun 29, 2015 12:27 AM
Mr.Black
Jun 21, 2015 10:17 AM
