radiator install question
Old Nov 7, 2006 | 10:13 AM
spudrunner's Avatar
Well just got my new radiator. My question is I have a manual transmission. The new radiator came with the auto trans cooler line attatchments . Well they're plugged off with a rubber boot. This shouldn't be a problem I hope. Thanks for any input!:pat:
Old Nov 7, 2006 | 10:14 AM
Elton's Avatar
use some hose clamps
Old Nov 7, 2006 | 10:23 AM
rezrunner92's Avatar
It is fine. I ran an auto radiator in my 2wd for two years until I sold it. Make sure to keep the trans cooler ports sealed.
Old Nov 7, 2006 | 10:25 AM
waskillywabbit's Avatar
Seems like whomever you got the radiator from should have asked you about the tranny...as the auto and manual radiators differ, as you now know. Hose clamps certainly seem like they would work, but that extra cooler might cause interference issues if it is not the OEM replacement radiator.
Can you not return it for the OEM replacement radiator?
P.S. I can get radiators.
Old Nov 7, 2006 | 10:44 AM
spudrunner's Avatar
Thanks guys, I'll go get some clamps right now.
Old Nov 7, 2006 | 12:30 PM
breknraj's Avatar
In the case of my new radiator, I asked about it. Performance Radiator only makes one unit for both manual and automatic applications. I'll just keep the tranny cooler nipples capped off.
Makes sense from the manufacturing aspect, and it's no skin off my nose, as long as the main radiator does it's job. I don't have a need for it here in the high country, but I suppose you could use it as and alternate oil cooler, if you wanted to.
Old Nov 7, 2006 | 01:46 PM
funjumper's Avatar
I spoke with the folks at radiator barn about using the trans cooler for oil cooling. According to what I was told, the trans cooler won't handle the pressure from the oil system. It would work for a short while, the internals would rupture, and I would end up with a nice blend of oil and coolant cirulating through the motor.
This seemed like BS to me. I capped off the nipples anyway. Too much hassle for not enough benefit.
Old Nov 7, 2006 | 02:21 PM
Nic's Avatar
Nic
It shouldn't be any problem. I replaced the radiator on my old Camry when the top split on the old one. The replacement Chinese made radiator from Advance Auto had the cooler lines coming out the bottom. I just left the nipples on and installed it. I haven't had any trouble out of it yet.
Old Nov 7, 2006 | 02:25 PM
s_wall98's Avatar
Doesn't matter if its plugged or not. If nothing goes in, nothing comes out.
Old Nov 7, 2006 | 02:36 PM
spudrunner's Avatar
Problems!! Installed it, started it up, no leaks, new upper and lower hose from Napa and a new cap. It starts to boil over like the thermostat is not opening up, had the heat on full blast and it was blowing cold. It's a brand new factory thermostat and waterpump less than 30 miles. Could it be an air pocket? Help!!!
Old Nov 7, 2006 | 02:47 PM
s_wall98's Avatar
Are you sure the thermostat is on right, not flipped around? Besides that I dont know.
I am sure about the cooler lines though. Installed a new radiator in mine about 8 months ago and haven't leaked a thing from them.
Old Nov 7, 2006 | 02:55 PM
spudrunner's Avatar
yeah it's right, no problems till this install.
Old Nov 7, 2006 | 03:25 PM
trx125's Avatar
Bad t-stat! Take it out an test it! Use pan of boiling water and drop it in it should open up completely, if not take it back and get a new one!
Old Nov 7, 2006 | 03:53 PM
spudrunner's Avatar
Dealer just put in a new thermostat and water pump 2 weeks ago. Just went out and started it again and it took another 1/2 gallon of 50/50 mix. That's why I think I may have an air pocket. Still no heat and can't see any circulation with the cap off. It's a 3.0 with a 3 row radiator. When I drained the old one out it was about 2 gallons of antifreeze give or take. When I filled up the new one it only took a gallon, now got another 1/2 gallon in it that's why I'm thinking I've got an air pocket. Thanks for all and any advice.
Old Nov 7, 2006 | 03:55 PM
Elton's Avatar
how did you try getting the air pockets out ?
Old Nov 7, 2006 | 04:30 PM
anthony1's Avatar
You can try parking on a hill....when engine is cool, open the cap....starts engine and look for bubbles....
When I changed my radiator, I just let it run with cap open and add liquid as I need it.
Old Nov 7, 2006 | 04:39 PM
spudrunner's Avatar
It's all good! Went out again, drove it around the block a few times watching the temp gauge, turned the heat on and it worked great. Parked it and took the cap off, started it again and it took another 1/2 gallon of coolant. Drove it around again, checked it and it was full, had to add to the overflow tank though, I'll keep an eye on it for the next few days but I think everything is fine, thanks everybody!
the1998sr5
15
Jul 14, 2020 08:35 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
rushw
Jul 18, 2015 01:46 PM
Coreyr384
Jul 10, 2015 11:13 AM
Avenged
Jul 9, 2015 07:55 AM
