oxygen sensor?
Old Nov 10, 2006 | 06:22 PM
itsmeagain5789's Avatar
oxygen sensor?
anyone know how to check the oxygen sensors on a 3.0 4runner? is that even possible without a scanner?
Old Nov 10, 2006 | 06:28 PM
Elton's Avatar
dont think theres anyway with out knowing what codes its throwing
Old Nov 10, 2006 | 06:41 PM
dcg9381's Avatar
Check your FSM. You can test it under operation. Basically you get the engine warm, then make sure that the 02 sensor is "dithering" - moving from about .25v to .75v under normal conditions at abou 1400 rpm or so...
Old Nov 11, 2006 | 08:12 PM
mtnfreak's Avatar
Unplug the sensor (probably under the driver's seat). Resistance between the two terminals away from the mounting plug should be between 5.1 & 6.3 ohms @ 68degF. Post your results - if you need more info, I can post it, but it'll be long.
moparbay
Mar 10, 2023 03:50 PM
jb451
7
Oct 7, 2022 06:58 AM
Kreedy1
Sep 8, 2015 06:33 PM
zz_denis
Sep 6, 2015 03:43 PM
moparbay
Sep 3, 2015 12:48 PM
