Are new headbolts REALLY necesarry?
Old 11-07-2006, 02:51 PM
pruney81's Avatar
My girlfriends cousin is going to replace my blown headgasket on my 95 3.0 and he swears that new headbolts aren't necessary. I'm gonna let him do it, should I insist that he use new headbolts or let it go? Paul Oh yea he is a toyota tech.
Old 11-07-2006, 02:56 PM
04 Rocko Taco's Avatar
Use the new headbolts.
You'llkick yourself if you don't.
They may not be neccesary, but toyota made them for one use only, why not replace, better safe than sorry, right?
Old 11-07-2006, 03:03 PM
MonsterMaxx's Avatar
Absolutely YES.
Once you install a set you'll understand why. Torque to 33, then turn 90° and turn another 90°.
My torque wrench was reading over 112ft-lbs and clearly stretching the bolts.
They are torque to yield and do yield when you torque them down.
Do not under any circumstances reuse.
Bassinfool's Avatar
I reused mine, twice. First time after spinning a rod bearing, second time after blowing a head gasket (not because of head bolts, because of water pump failure). Never had any problems with reusing the bolts personally.
Edit:
Disclaimer: Though I am an idiot, it was the parts guy at the local stealership that told me new ones weren't necessary. Had I known they were, I would have used new ones.
Old 11-07-2006, 03:08 PM
pruney81's Avatar
Well he is a toyota tech and claims it's not necesarry, although from what I've read on here it seems it is. I tried tellling him last night to use new headbolts and he assured me it wasn't necesarry. I'm leaning towards calling him and asking him to use them again but I don't want ot bug the guy about it before he fixes my car you know
Old 11-07-2006, 03:13 PM
snap-on's Avatar
engbldr head bolts are like $30...
for the amount of time involved seems like really cheep thing to skimp on given what happens if they dont hold (like they are known to do an reuse)
Old 11-07-2006, 03:22 PM
surf4runner's Avatar
^ not enough time to do it right the first time, but enough time to do it again
just get new ones and swap em when hes not looking
Old 11-07-2006, 03:58 PM
Elton's Avatar
get new ones unless it was fun for you to take the heads off and then have to do it again do to blown hgs and have to spend more money its up to you
Old 11-07-2006, 03:59 PM
Dublin's Avatar
Absolutley replace TTY bolts, they are designed to be used only once. It has something to do with stretch and compression (and to conpansate for temperature, contraction/expansion). Back in the day (before Torque To Yield) most heads required a re-torque after a certain mile/hour usage for the same reasons. If your tech refuses to use new bolts see if he will redo the job when (not if) it fails. For Free.
Old 11-07-2006, 05:03 PM
pruney81's Avatar
yea I called him tonight and left him a message....I'm gonna call him back in a few days, I told him last night that they were torque to yield but he said it didn't matter, He works for Toyota you'd think he'd know about it. On the other hand he told me that at the dealership all they do is replace the headgaskets and put it back together to the tune of 1500 bucks go figure
Old 11-07-2006, 05:29 PM
curtiswyant's Avatar
They might be ok, but why take the risk? Seems like a no-brainer to me. It's worth the $25 bucks to avoid another headgasket problem or worse down the road.
Old 11-07-2006, 05:44 PM
MMA_Alex's Avatar
the head bolts are torque to yield meaning that they are designed to be stretched to the point where they wont return to their origional form. All tty bolts should be replaced when removed. Its worth spending a few extre $ to save yourself many hours of work on down the road.
Old 11-07-2006, 05:56 PM
pruney81's Avatar
yea I know, it's just that I'm not doing it myself, My girlfriend's cousin, who happens to be a toyota technician is gonna do it. I dropped the car off last night and mentioned the need for new headbolts but he said I don't need them. It's gonna be a pain in the ass to convince this guy but it seems like I have to.
Old 11-07-2006, 06:51 PM
Don't let idiots work on your car!
Old 11-07-2006, 07:11 PM
CyMoN's Avatar
are you paying this guy to do this HG job? if so I would demand that he uses new bolts or like what dublin said will he replace the head again if it fails free of charge for the parts ect.
it is your truck and if he cant under stand that you dont want to take the risk down the road I would find someone else to fix it or help you fix it.
my.02 cents
Old 11-07-2006, 07:36 PM
runethechamp's Avatar
I'd change the headbolts. I don't know the exact theory behind why they use torque to yield bolts, but here's what's going to happen if you reuse them. When steel is stretched (or strained as it's called in engineering) past its yield point, you experience something that's called strain hardening. That means that the steel actually gets stronger. When you re-use your bolts, you actually have stronger bolts than your old ones. When you torque the headbolts up the specified torque, everything is the same. That extra quarter plus quarter turn will cause the same elongation or strain of the headbolts as before, but because the steel is stronger, the bolts give a higher downward force on the head. That means more force and pressure on the new headgasket, and I guess, it will make the headgasket more prone to breaking.
This is all just derived from my general engineering knowledge, so any additional info or corrections are very welcom.
Old 11-07-2006, 07:44 PM
Tigerstripe40's Avatar
How much are you spending on the head gasket job?
$1300 for parts and labor?
So, when you're spending $1300 (or $300 for that matter) whats wrong with an extra $30-$50 for the peace of mind that new headbolts cost?
Sure, the Toyota tech's going to recommend reusing the head bolts if you're looking at the cost of OEM head bolts ($300 or so), but you can get headbolts that are just as good from engnbldr...
Old 11-07-2006, 07:58 PM
rocket's Avatar
show him this thread!
Old 11-07-2006, 09:24 PM
Propayne's Avatar
if these headbolts are like newer ones...they stretch and sort of bend and twist when more torque is applied to them
Old 11-07-2006, 09:49 PM
95ToyotaPU007's Avatar
$6 a piece at stealership
Quick Reply: Are new headbolts REALLY necesarry?
