Can't find diagnostic connector.
Old Nov 9, 2006 | 06:11 PM
carova_kevin's Avatar
86 4runner 22re, trying to read code, book says the diag. connector is near the coil, not sure which connector it is, doesn't specify. Don't see any lables either.
If somone could tell me where, what shape, how many terminals, anything would be great. thankx in advance
Old Nov 9, 2006 | 06:18 PM
86SR522REEFI's Avatar
Its right next to the coil like it says, there should be a black plastic cover on the terminal.
Old Nov 9, 2006 | 06:21 PM
914runfun's Avatar
Hey had that prob befor. If the there is a fuze box to the left of the moter (not sure if its the same on 91)its connected to the back of it. It will be marked. Hope it helps.
Old Nov 9, 2006 | 06:22 PM
amgraham's Avatar
Mine is next to the underhood fuse box. I don't know if they changed it for the 87s but you might want to check there. It should have a cover that says "Diagnostic" but if the cover is gone it should be the only open rectangular plug around there.
Old Nov 9, 2006 | 07:11 PM
TWolf's Avatar
I also have an 86' when i put the 87 motor in i got the diagnostic port that actually says diagnostic. On the 86 you've got two yellow plugs that just sort of hang next to the air box, there supposed to plug into little holders on the driverside fender but mine never stayed. One is bigger than the other, if i recall it's the bigger of the two that you need to jump to get codes to flash. good luck
Old Nov 9, 2006 | 08:42 PM
4runnerx3's Avatar
4crawler photos My 86 has two round plugs behind coil
My 88 has a plug behind the battery
http://Name:  TccsDiag.jpg
Old Nov 9, 2006 | 10:04 PM
I saw the yellow plugs on fender, but what wires do i jump, there is three, i didn't see T1 or E1 on it
Old Nov 9, 2006 | 11:13 PM
rezrunner92's Avatar
Go ahead and take the truck to a shop and have them diagnose and correct the problem. If you don't have enough sense to search and corrrect this on your own then this is what you need to do.
Not trying to be mean only realistic. If you don't have enough sense to search this forum before asking this type of question, you REALLY need a mechanic.
Old Nov 9, 2006 | 11:14 PM
PS my wife could take pictures of her fuse box, that doesnn't qualify her to work on it.
Old Nov 9, 2006 | 11:15 PM
And yes I AM TRYING TO BE HELPFUL!!!!!!!!!!!!!!!!
The people who are telling you to tackle this yourself are not.
Old Nov 10, 2006 | 12:58 AM
bikeguy18974's Avatar
The poster probably could have searched better but sometimes no matter how much you search you can't find what you want. There've been numerous posts I've read and later can never find when I realize i need them. Or I am just a lousy searcher.
Anyway kevin, yotatech in its infinite wisdom has searched for you now that you've posted. Scroll down to the bottom of the screen past the quick reply and other stuff and you'll see the "Similar threads" heading.In the thread with "check connector" in the title 4crawler has detailed all of the check connectors and which one you need. Read that whole post as well as the link to the 4crawler site in that thread and you have your answer.
Old Nov 10, 2006 | 04:30 AM
waskillywabbit's Avatar
X2. Classic.
You get a gold star.
Old Nov 10, 2006 | 05:48 AM
Thankx bikeguy, i may not be the most computer friendly guy in town, but i have yet to come across a problem that i couldn't fix.....so criticize all you want, i know what im capable of.
Old Nov 10, 2006 | 07:04 AM
fire5's Avatar
I never worked on vehicles in my life until my first yota 2+ years ago and I've managed quite well. Look at the picture above. It is the SMALLER of the two yellow connectors. Mine is 86 22re pickup. They are located by the air box like previously mentioned (driver's side). Nothing on it is labled T1 or E1. Take a paper clip or short 1 to 1-1/2 inch (I used a wire from a 84 headlight bundle with the ends exposed). Bend it in a "U" shape and set an end into each opening - there are only 2 openings in the smaller connector. Doing this will flash your check engine light whatever number of times to show you what area to look.
Old Nov 10, 2006 | 07:39 AM
Got it! Thanks for the help, i don't know why they didn't at least lable the terminals.
Old Nov 10, 2006 | 05:08 PM
4runnerx3's Avatar
Do this to the plug with two wires. A paper clip will work.
Here are the codes.
Sleaker
Aug 26, 2020 06:03 AM
HookahRoo
Jul 20, 2015 07:06 PM
scottyg486
Jul 19, 2015 05:34 PM
sojourner567
Jul 16, 2015 08:52 PM
Sandman
Jul 14, 2015 12:36 PM
