steering box link, cant get it off?
Old Nov 6, 2006 | 08:35 PM
94toyota4x4's Avatar
Question steering box link, cant get it off?
How do you get that braket off the comes from the steering box and meets at that steering link? heres a pic.
Old Nov 6, 2006 | 09:03 PM
EWAYota's Avatar
Ram it with your front bumper.
Old Nov 6, 2006 | 09:18 PM
DudeBud's Avatar
fork tool or a tie rod puller
Old Nov 6, 2006 | 09:21 PM
reggie 00's Avatar
Old Nov 6, 2006 | 09:34 PM
neilan's Avatar
haha ya that pretty much the amount of force it takes to get those thigns off usually. With my experience it seems like 1. you dont know how so you most likely dont have to puller already. 2. A puller cost about 45 bucks for a decent one ( crappy ones will usualy break befor the thing will budge). I have heard of peopel just cutting them off and buying a used one. It all depends on why you are taking it off
Old Nov 7, 2006 | 04:35 AM
Rory's Avatar
That joint...
It is an interference joint, as in the two metal pieces are designed at an angle so they wedge into eachother. Pullers are hard to use, forks are ok if you replace the joint; forks have a tendancy to destroy boots. The mechanic way is to beat the living hell out of the eyelet, without hitting or damaging anything else. And I mean hit it hard, with all your force, to the point where the metal even gets distorted a little bit. Sometimes can be fun, but usually just a HUGE pain in the ass. It would be a good idea to twist the nut on by hand to protect the threads.
Good Luck!
Old Nov 7, 2006 | 05:23 AM
sschaefer3's Avatar
Harbor Freight has a small U-Shaped puller that fits and works perfect on that. Very easy with that tool.
Old Nov 7, 2006 | 06:45 AM
Intrepid's Avatar
Hard to tell in the pic, but if that is stock, the joint is built into that pitman arm. He still would have to remove it and weld in a tapered insert to allow a tie rod end to be used.
Old Nov 7, 2006 | 06:51 PM
wow, well can i beat the hell out it wiht a hammer? or is it weaier to take that big nut off trying to get the steering box out
4x4-runner
Apr 18, 2017 09:08 PM
delmert
Sep 30, 2015 04:34 PM
Scotto6591
Sep 1, 2015 03:24 PM
4x4-runner
Aug 30, 2015 08:55 AM
4x4-runner
Aug 2, 2015 09:24 AM
