How do I replace this pulley bolt?
Old Nov 15, 2006 | 03:14 PM
linuxrunner's Avatar
So how can i replace this? I need to get a new head on the bolt before i try to do my valves again. Thanks
Old Nov 15, 2006 | 03:55 PM
midiwall's Avatar
Replace what ???
I'm thinking that there's a pic missing from your post, but if you snapped a head off of a bolt, then you'll need to EZ it out and replace it. If you can't get it out, then you'll need to drill it out and drop a HeliCoil in there.
Old Nov 15, 2006 | 04:19 PM
My bad...
It's a pulley... i think water pump, or somewhere close by anyway
Old Nov 15, 2006 | 04:27 PM
all_terrain17's Avatar
Looks like the nut for the pulley on the PS pump...I'd try soaking w/ PB blaster for a day and then try hammering on a SAE socket of the closest size on (which will ruin it of course...but who cares its SAE )
Old Nov 15, 2006 | 04:35 PM
CJM's Avatar
CJM
Bolt off would be easier, they sellt hem at home depot or the autoparts store for about 20 bucks for a set if you dont wanna ruin a socket or maybe snap the head of the bolt off.
Old Nov 15, 2006 | 04:38 PM
my question is when i turn it it tuns the pulley, (and engine) so how do i get the bolt off?
Old Nov 15, 2006 | 04:50 PM
4runnerx3's Avatar
go to Sears and get this set of nut removers.
Old Nov 15, 2006 | 04:52 PM
isaac338's Avatar
impact gun.
CJM's Avatar
CJM
Block the pulley somehow, or hold the shaft with a wrench.
Old Nov 15, 2006 | 04:53 PM
HAVOC's Avatar
An impact gun will do it, but only if you have access to air.
Old Nov 15, 2006 | 06:07 PM
4runnerx3's Avatar
Pinch the belt next to the pulley with vise grip pliers.
Old Nov 17, 2006 | 09:04 AM
InternetRoadkill's Avatar
A box-end wrench and a hammer. Smack the handle of the wrench with the hammer. Be sure to tighten the belt up good to discourage the pulley from slipping.
BTW, that looks to be the power steering pump. Why are you taking the pulley off?
Old Dec 26, 2006 | 10:42 AM
i am just trying to replace the nut so that it will not cause a problem later when it is too stripped to use.
This is what i was told to use to turn the engine over for valve adjustment, but it is too stripped to get a good hold on, so i am trying to replace it first.
Old Dec 26, 2006 | 11:19 AM
BLKNBLU's Avatar
You will probably need a strap or chain wrench like one of these:
http://www.ridgid.com/Tools/Chain-Wrench/index.htm
http://www.ridgid.com/Tools/Strap-Wrench/index.htm
Have a friend hold the strap/chain wrench while you crank on the nut with a breaker bar. You may still need the nut removing tool as listed above in post #7 as well. If you use a chain wrench instead of a strap wrench, wrap the pulley with a rag to protect the surface.
Old Dec 26, 2006 | 11:29 AM
vetteman1's Avatar
I had some luck with PB blaster soak 24 hrs. Put a strap or chain wrench around the pully ( sometimes a good heavy rag works also) and use an impact wrench on the bolt.
Old Dec 26, 2006 | 08:15 PM
rhah's Avatar
It's a nut thread onto a shaft w/ a allen key dead center of the shaft just like 99% of the pulleys that are belt drivin....heat the nut cherry red then quench it with water.
Old Dec 26, 2006 | 08:32 PM
PirateFins's Avatar
Ok all good suggestions.
My question
Why are you trying to turn the motor over with the PS pulley bolt? Use the 19mm main crank bolt for that (the bolt that holds the main pulley with the timing marks on it).
Old Dec 26, 2006 | 09:06 PM
midnightoys's Avatar
use the 19m bolt on the main pully thats where your soposed to do it from read the manual.
Old Jan 5, 2007 | 09:42 PM
strategy400's Avatar
Dremel tool w/ cutoff disc and chisel or nut splitter.
Old Jan 22, 2007 | 08:52 AM
Thanks all for the suggestions, Basicly i was told by the previous owner that he thought it needed the valves and timing chain looked at and that was the bolt to turn to get the engine to turn to the right spot for valve adjustment, (by the looks of it that is what he used anyway) However i had not yet used that bolt, becuase i wanted to replace it before i tried the valve adjustment. Thanks much to all, i will use the 19m bolt on the main pully. And will try to never ever have to replace the PS pully!!
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87blyota
Jul 10, 2015 04:31 AM
Snort
Jul 9, 2015 03:58 PM
