simple Q re: ADD to manual hub swap
Old Nov 13, 2006 | 07:44 PM
Brendan's Avatar
when you remove the gold dust cap on the ADD hub, there is a bolt underneath. does it need to stay? does it matter if it does or does not?
Old Nov 13, 2006 | 07:47 PM
Elton's Avatar
i think thats the hub bolt .... its the really big one right ?
Old Nov 13, 2006 | 08:06 PM
Brendan's Avatar
nope, it's got a 12 or 14mm head. dead center on the hub
Old Nov 13, 2006 | 08:11 PM
Brendan's Avatar
it's been removed in this picture
Old Nov 13, 2006 | 08:30 PM
Flygtenstein's Avatar
ADD is vacuum.
The flange is not a hub.
No need for it, doesn't hold things any particular way.
Old Nov 13, 2006 | 08:33 PM
Brendan's Avatar
okie dokie. isn't that still part of the hub?
Old Nov 13, 2006 | 09:15 PM
tc's Avatar
tc
I put it back in, but it doesn't really seem to hold to anything like it did in the ADD flange...
Old Nov 14, 2006 | 01:54 AM
91 4Runner's Avatar
The .pdf has it installed....and so does a picture from the service manual...Also in this link... https://www.yotatech.com/forums/show...in+hub+rebuild
Old Nov 14, 2006 | 01:55 AM
91 4Runner's Avatar
And the .pdf to make it easier to find....http://www.yankeetoys.org/Documents/AisinHubs.pdf
Old Nov 14, 2006 | 03:26 AM
excableguy's Avatar
I just did an ADD swap and I thought it helped to retain the cv axle from pulling out or just moving around so much--I know I had everything apart and couldnt remove the axle until I remembered to remove that bolt, if it is the gold 12mm bolt your talking about. I may be way off on this, but it's just an idea
Old Nov 14, 2006 | 04:12 AM
AH64ID's Avatar
All I could tell it was there for was to hold the drive flange on if it came loose. I dont recall my Warn Hubs using it.
Old Nov 14, 2006 | 05:58 AM
axon's Avatar
I just changed mine over and I replaced that bolt so it wouldn't get lost if I needed it later
Old Nov 14, 2006 | 12:52 PM
TNRabbit's Avatar
The bolt goes in to assist in holding the AISIN hub in, just in case you lose every single cone washer & associated bolt...'
Old Nov 14, 2006 | 01:04 PM
CJM's Avatar
CJM
My warn hubs have it, dont remove it otherwise in the rare case everything comes off it will still hold on. Wanna replace some bolts or an entire hub?
Old Nov 14, 2006 | 02:08 PM
Mister Willie's Avatar
I replaced my CV shaft on my 90 4runner 6 weeks ago and when we pulled that dust cap off, the gold washer/bolt on the end of the shaft was what was holding my shaft in place. We dug further and found that the C-clip that snaps onto the little groove in the splines was very loose and easy to take off.
So dont permanently remove that washer and bolt, besides, it's only a few grams of weight, nothing major.
Old Nov 14, 2006 | 02:41 PM
Robinhood150's Avatar
I never re-installed mine. Seemed to work fine to me.
Old Nov 14, 2006 | 04:03 PM
95RunnerSR5's Avatar
same here
Old Nov 14, 2006 | 04:43 PM
typical8o8's Avatar
you have to take it off to install aisin manual hubs. after installing the manual hub body, it's optional whether or not you want to put it back on.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
oldirtydirt
Feb 23, 2020 09:30 AM
KBar
Jul 13, 2015 06:01 PM
Steven.m.paulk
Jul 13, 2015 01:40 PM
ItsJustD
Jul 7, 2015 07:49 AM
