Rear Differential
Old Nov 6, 2006 | 01:42 PM
LegendofJake's Avatar
Rear Differential
so i took the filler plug off of the rear differential to check fluids and I twisted it off but it wouldnt come all the way off or go all the way back on its on but not all the way how do i put it all the way back on
Old Nov 6, 2006 | 01:54 PM
rngrchad's Avatar
Use a socket and ratchet. I think it's a 27 or 30 mm plug.
Old Nov 6, 2006 | 02:02 PM
nah im talking about the one towards the top
Old Nov 6, 2006 | 02:08 PM
MMA_Alex's Avatar
I'm kinda confused as to what exactly the issue is? it came out but wont thread back in? you did use the right plug right? it is a hex headed socket, I believe 22mm
Old Nov 6, 2006 | 02:14 PM
ok theres the hex one on the bottom and at the top theres a little rubber circular plug im trying to take off to fill the differential but it wont go all the way back on
Old Nov 6, 2006 | 02:17 PM
Firefightertaco's Avatar
I take it your not talking about a toyota, but my dodge had just a rubber plug in it for the fill plug, just push it back in and it should go in.
Old Nov 6, 2006 | 02:22 PM
its a 91 4runner
Old Nov 6, 2006 | 02:30 PM
Reldnew's Avatar
Are you talking about the vent on the top of the diff?
The fill plug should be 2/3 of the way up on the back of the pumpkin, looking at the diff from the back of the truck. Fill it till it comes out the hole and your good to go.
Old Nov 6, 2006 | 02:44 PM
MMA_Alex's Avatar
yeah the fill plug is the hex one on the back, the drain is the hex one on the bottom of the casing. If you're trying to remove the little rubber thing on the drivers side top thats the diff breather
Old Nov 6, 2006 | 03:49 PM
anthony1's Avatar
That's the diff breather.
search here on diff breather then replace it. As others have said, the filler hole is about half way up from bottom.
Old Nov 6, 2006 | 03:52 PM
waskillywabbit's Avatar
Do yourself a favor and buy a manual before you break something or check the owner's manual for your vehicle, if you have one. It sounds like you are really lost as to what is what on your differential and you need to know what is what before you start unbolting things.
Top left is the diff breather.
Middle hex head is the fill plug (towards the right side of the diff)
Lower left hex head is the drain plug (bottom on the left side of the diff)
I replaced mine w/ socket head plugs that use a 10mm, much easier to r/r.
Good luck.
Old Nov 6, 2006 | 04:08 PM
Hah yeah I'm stupid . For some reason I thought it would be ok from looking at my owners manual there was only a diagram and they didnt label any of the parts so i was kind of lost
Old Nov 6, 2006 | 04:11 PM
rezrunner92's Avatar
Wabbit, is that plug from a later model Yota? I would like to change mine to these when I put on diff armor, what do I need to ask for?
Old Nov 7, 2006 | 10:25 AM
anthony1's Avatar
Call Budbuilt.com
They can sell you some.
Old Nov 7, 2006 | 10:29 AM
Talking
Nah, not stupid, just a bit lost. Better to ask questions and find out than screw something up cause you won't ask.
I got them on my website on the "differential" page. I'd be glad to hook you up with some...for the diffs, tranny, just look at the descriptions on the website page.
http://www.wabfab.org/products/diffe...ferentials.htm
Ladythump
22
Nov 9, 2015 08:53 AM
jerusry
Oct 19, 2015 05:28 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
scottyg486
Jul 19, 2015 05:34 PM
AaronM
Jul 8, 2015 07:15 PM
