93 4runner Crazy Rpm
Old Nov 15, 2006 | 03:54 PM
Midnight Skys's Avatar
I just got my 4runner back from having a head gasket replaced and when i was on the highway it started jumping about 500 rpm's it would go from 2000 to 2500 and back and it would do this on and off. It stopped later on that day, its been about a week or two since that happened, but it just started doing it again and its getting checked out now. The mechanic doesn't know whats wrong, he thinks it could be a sensor or a solenoid but he cant even find out which one. He's going to talk to a friend at a toyota dealership tommorow, i'am just baffled and hope it can get fixed soon and was hoping i might get lucky and someone might have experienced this and know what to do.
Thanks for any Feedback, i miss my yota
Old Nov 15, 2006 | 06:59 PM
AH64ID's Avatar
That happened to me when my alt was acting up... I think its an electrial issue... I dont recall where the tack gets its reading, but I wanna say the dist. but thats a 22RE and I dont know what engine you have.
Old Nov 15, 2006 | 07:29 PM
dcg9381's Avatar
throwing codes?
Old Nov 15, 2006 | 07:51 PM
mercury89's Avatar
Does just the tach. move or is the engine revving up and down on its own. If the engine is revving up and down then it is probably the Oxygen sensor. Have that checked and let us know what happens.
Old Nov 15, 2006 | 09:03 PM
Mister Willie's Avatar
I had this happen to me, not long after I bought my 90 4runner a year and a half ago. It would jump from like 3 to 3.5 to 4k RPM at 75 in 5th, where it should be 3k. It was only the tach, cause the speedo and everything else was acting normally. Shortly after, I started having Alt showing negative charge problems and I went to the dealership and got a new Remanned one. Haven't had problems since, infact I forgot about that problem until I read this post.
Old Nov 16, 2006 | 07:20 AM
Yea, the engine is going with the rpm's to, and i have a 22re. Hopefully i'll find out later today, i'll post back when i find out the hopefully good news.
Old Nov 16, 2006 | 08:54 AM
Marc's Avatar
You don't say if it's an auto or not.
If it's an auto, a 500 rpm difference sounds like the torque converter locking/unlocking.
Try driving it with the O/D off and see what happens.
Old Nov 16, 2006 | 09:35 AM
the_4runnin'_beast's Avatar
Yeah. Check the ATF level if auto as well.
Old Nov 16, 2006 | 10:28 AM
My bad, it is an automatic, i tried alternating the overdrive but it did the same thing whether it was off or on. The tranny fluid was about 3/4 low when this showed up but it continued even after filling it up again.
Old Nov 17, 2006 | 03:23 PM
Well, i just got the truck back, its still broken but the problem has been diagnosed. It turns out its a solenoid and its messing with the gears and when they should shift. Its gonna cost 600 for a new one, but hopefully i can get a used one. Anyone have a price idea on a used one?
Old Nov 18, 2006 | 10:23 AM
just switch it to a manual transmission.
Old Nov 18, 2006 | 03:48 PM
Babypig's Avatar
Do a search on here for shift soleniods. Pull the codes watching the O/D light and find out what code its throwing. Solenoids are easy to change and should only be around $150 or so.
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
88runnergomas
Jul 9, 2015 01:12 PM
shar
Jul 9, 2015 12:38 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
