power steering knocking
Old Nov 14, 2006 | 08:55 AM
dbfarrier's Avatar
the power steering in my 95 tacoma 4x4 is knocking intermittently and i was wondering if anyone has any suggestions? I just ordered a new one and will replace it. Anything i should look out for?
Old Nov 14, 2006 | 08:57 AM
dbfarrier's Avatar
also need to know if anyone has any secrets to bleeding the new pump
Old Nov 14, 2006 | 08:58 AM
waskillywabbit's Avatar
A 95 Toyota pickup is just a pickup and they didn't make Tacos until 95.5, so you might have better luck posting this in that section, depending on actually what your pickup is.
Regardless, are you swapping out the pump or the steering box or both? It is all pretty much a straightforward task.
You'll have to bleed the whole system, not the pump, to get the air out. After you get the new pump on and fill back up the reservoir, put the front axle up on jack stands, crank the vehicle, and cycle the steering back and forth about 20 times. Turn off, let it sit about 30 minutes, check the reservoir. Refill if necessary. Repeat.
Old Nov 14, 2006 | 09:08 AM
dbfarrier's Avatar
thanks. Must be a 95.5. It says Tacoma
Old Nov 14, 2006 | 10:10 AM
RunnerUp's Avatar
it sounds like you just needed new bushings, about a 13$ part, you might want to order some poly ones while your installing the rack to prevent this from happening again
Old Nov 14, 2006 | 10:12 AM
harpen123's Avatar
mine was cutting out and i put a new belt on and tightened it up and it works better then before.
Old Nov 14, 2006 | 02:58 PM
dbfarrier's Avatar
the knocking stops when i turn the wheel, so i figured it was the pump. I never knew about the bushings though. Thanks i'll look into that tomorrow.
Zpd426
Jan 2, 2016 01:15 PM
delmert
Sep 30, 2015 04:34 PM
Up&Down
Aug 11, 2015 10:04 AM
toyoterferdayz
Diesel Swaps
Jul 27, 2015 05:25 PM
gmonnie123
Jul 26, 2015 02:44 PM
